It is currently Mon Aug 18, 2025 12:28 pm
PostPosted: Sun Jun 14, 2015 7:49 pm
First name: Dan
Last Name: Cosgrove
City: Sand Lake
Zip/Postal Code: 49343
Country: U.S.A.
I sprayed a clear coat on my guitar body when it was very humid, thinking it would just take longer to dry, but the lacquer clouded up on me. It was from an aerosol can. Anyone know if there's a fix, or am I out of luck.
PostPosted: Sun Jun 14, 2015 7:52 pm
Mist it with some blush eraser, or some thinner.... sometimes it works.
Otherwise..... sand it back.
PostPosted: Sun Jun 14, 2015 7:54 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
Sometimes a hair dryer with light heat, or just time, wait it out, it will clear up.
Jason Moe
LaCrosse WI 54601
PostPosted: Sun Jun 14, 2015 9:02 pm
Not a problem. It will clear up when you spray your next coat. That is assuming that the next coat is not sprayed when it is too humid. lf you are not planning to spray another coat, then blush eraser will do it, as suggested above. No need to sand.
James
These users thanked the author guitarjtb for the post: Glenn_Aycock (Wed Jun 17, 2015 5:18 pm)
PostPosted: Mon Jun 15, 2015 10:05 am
First name: Dan
Last Name: Cosgrove
City: Sand Lake
Country: U.S.A.
Thanks for the info, good to know it's not ruined. I have several more coats to go and I learned my lesson about not spraying in humidity.
PostPosted: Mon Jun 15, 2015 11:59 am
First name: mike
Last Name: mcgrail
State: ky
just the cooling effect of solvent evaporating in too humid an environment. A slower evaporating lacquer thinner would usually allow you to spray in a bit of a humid environment, alright for autos when lacquer was used(man I'm old), but probably never okay for guitars, since we don't want to think about miniscule amounts of water condensing on our wood.
PostPosted: Wed Jun 17, 2015 10:11 am
First name: Dan
Last Name: Cosgrove
City: Sand Lake
Country: U.S.A.
The cloudiness did go away when I sprayed another coat. What a relief!
