Source of 3"x4" maple neck stock?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=45733
Author:  sdsollod [ Sun May 17, 2015 11:45 am ]
Post subject:  Source of 3"x4" maple neck stock?
Does anyone know of a source of a maple neck blank that is 3"x4" that I can cut out 2 necks from? I can find vendors that sell 1"x4" boards, but I think I would rather have a solid neck or at least laminated...
Author:  kencierp [ Sun May 17, 2015 12:23 pm ]
Post subject:  Re: Source of 3"x4" maple neck stock?
I use turning "spindle blanks" they can range from 1 1/2" to 4" even 6" at times, often they are perfectly 1/4 sawn. Most reputable hardwood suppliers should have them.
Author:  SteveSmith [ Sun May 17, 2015 2:32 pm ]
Try Jerry at American Specialty Hardwoods. He will probably get you whatever size you need.
Author:  Barry Daniels [ Sun May 17, 2015 2:43 pm ]
Get 3 of the 1" boards, turn them up on edge, and laminate.
Author:  Glenn_Aycock [ Mon May 18, 2015 6:51 am ]
You do realize that the short grain in one-piece necks makes the headstock more prone to breaking, right? This is a very common problem in Gibsons (and others), especially with high tension (electric and steel) strings.
The laminated scarf joint is significantly stronger and fairly easy to do.
Good luck,
Glenn
Author:  SteveSmith [ Mon May 18, 2015 10:08 am ]
Good luck,
Glenn
Not as much of an issue if the truss rod adjustment is not in the headstock.
Author:  Glenn_Aycock [ Wed May 20, 2015 6:49 am ]
Less so in maple too, I would imagine?
Author:  Peebs [ Thu May 21, 2015 6:59 pm ]
Hibdon had some the last time i was there.
Author:  cphanna [ Thu May 21, 2015 7:34 pm ]
Steve,
I'll offer my opinion that you should do EXACTLY what Barry Daniels advised you to do. I have read your post that you don't think the short grain through the neck-headstock area is much of an issue if you have your truss rod adjustment end reversed. I personally think you are mistaken about that. Short grain is short grain. Even with side wings and top and back plates to reinforce this area, it is still vulnerable to breaks. But I know your opinion is formed and firm in your mind. You can make two necks out of the blank you propose and, if you are very careful with them, they will both outlive you. But you could be a might safer doing what Barry recommended, then gluing on side wings, and then gluing on top and back plates. Even if you do what Barry and I do, that area will always be vulnerable.
Author:  violinvic [ Sun May 24, 2015 5:36 pm ]
" The Woodwell" for all your maple needs. I have been getting great maple from them for several years.
