Vacuum clamping: what kind of rubber/foam tape to use? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=45725 |
Author: | James Ringelspaugh [ Sat May 16, 2015 4:25 pm ] |
Post subject: | Vacuum clamping: what kind of rubber/foam tape to use? |
I'm doing a bunch of pattern routing in the next couple of weeks and figure putting foam/rubber tape on both sides of my templates and using them as both vacuum clamp and pattern will work best. There seems to be a dizzying array of foam/rubber tapes on the market advertised as various weatherstripping and gasket tapes... what's the best to use for this application? |
Author: | SteveSmith [ Sat May 16, 2015 6:17 pm ] |
Post subject: | Re: Vacuum clamping: what kind of rubber/foam tape to use? |
Look for something that is closed cell. I got what I use from Joe Woodworker. |
Author: | printer2 [ Sun May 17, 2015 9:44 am ] |
Maybe not the best but it was cheap and within reach. ![]() |
Author: | Imbler [ Sun May 17, 2015 11:29 am ] |
I love it! Very creative Printer2! Is that just saran wrap? |
Author: | printer2 [ Sun May 17, 2015 11:54 am ] |
Imbler wrote: I love it! Very creative Printer2! Is that just saran wrap? The one and only. Well maybe not only. |
Author: | Don Williams [ Sun May 17, 2015 2:12 pm ] |
Check into Allstar Adhesives... They have all kinds of stuff. http://www.allstaradhesives.com/ |
Author: | kencierp [ Sun May 17, 2015 2:20 pm ] |
I've purchased the stuff Joe WW sells and also used the water seal adhesive back rubber found in the RV and boat maintenance supply stores. |
Author: | Jim Watts [ Sun May 17, 2015 6:55 pm ] |
+1 on Allstar Adhesives. o-ring cord stock also works. Here another low tech clamping bag, which works pretty well actually. |
Author: | Bob Garrish [ Sun May 17, 2015 11:08 pm ] |
Neoprene round cord is where it's at. As others said: if you can't get it locally, Allstar Adhesives has what you need. The round cord works best, and I use it with a square bottom groove cut just a bit over half its diameter. I use the 3/16" stuff just because. Pretty much anything works well as a vacuum bag- we often use clear garbage bags at work. You can seal the bag to the hose with electrical tape, or even a few zip ties. |
Author: | James Ringelspaugh [ Mon May 18, 2015 11:59 am ] |
Thanks all... turns out I can use some new veneering supplies too so I went with this Joe Woodworker tape: http://www.veneersupplies.com/products/ ... x-100.html |
Author: | SteveSmith [ Mon May 18, 2015 12:36 pm ] |
That's what I was referring to. |
Author: | kencierp [ Mon May 18, 2015 12:44 pm ] |
James Ringelspaugh wrote: Thanks all... turns out I can use some new veneering supplies too so I went with this Joe Woodworker tape: http://www.veneersupplies.com/products/ ... x-100.html Yep -- that's the stuff -- sticks good, functions perfectly. |
