Bracing chisel uk http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=45526 |
Page 1 of 2 |
Author: | Cablepuller [ Sun Apr 12, 2015 3:28 pm ] |
Post subject: | Bracing chisel uk |
Hi Can anyone recommend a good place to buy a curved bracing chisel in uk. Dont want to spend to more than £20 really Thanks |
Author: | Steve Jeffries [ Sun Apr 12, 2015 3:32 pm ] |
Post subject: | Re: Bracing chisel uk |
Instead of shelling out a lot of money, all I did was just put one of my Marples into a vice and bent it to my liking. Works like a charm. |
Author: | Cablepuller [ Sun Apr 12, 2015 3:34 pm ] |
jeffrodite wrote: Instead of shelling out a lot of money, all I did was just put one of my Marples into a vice and bent it to my liking. Works like a charm. Jeff Was wondering if that was a possibility. .. thought because its hardened it might shatter What size chisel was it Cheers ![]() |
Author: | Cal Maier [ Sun Apr 12, 2015 3:46 pm ] |
You don't need a curved chisel to carve braces, just flip a bench chisel over to carve the scallops. Have a look at this. https://www.youtube.com/watch?v=Lz-2OL_b-oU Cal |
Author: | Cablepuller [ Sun Apr 12, 2015 4:02 pm ] |
Cal Maier wrote: You don't need a curved chisel to carve braces, just flip a bench chisel over to carve the scallops. Have a look at this. https://www.youtube.com/watch?v=Lz-2OL_b-oU Cal Hey Cal Good video cheers But do want curved chisel as i think it will make it easier to carve the shapes .. especially the concave parts of the bracing Cheers |
Author: | mike-p [ Sun Apr 12, 2015 4:19 pm ] |
I think Axminster have them |
Author: | RustySP [ Sun Apr 12, 2015 4:20 pm ] |
You can also take an oxy-acetylene torch to it wherever you want the bend, it will bend like butter. Just make sure you keep the torch away from the sharp end of the chisel. |
Author: | Fred Tellier [ Sun Apr 12, 2015 4:46 pm ] |
I purchased a curved chisel but do not use it, the upside down chisel like in the Martin video works way better. I radiused the corners so it does not damage the top if it slips. Fred |
Author: | mqbernardo [ Sun Apr 12, 2015 4:48 pm ] |
I know you said twenty quids, and uk but I can't help to head you to wilco flier's chisels : http://wilcoflier-toolworks.blogspot.pt ... isels.html 50 eur and in the nederlands. Really high quality stuff, and made to your specs. Recommended. Anyway, just an heads up. |
Author: | Pmaj7 [ Sun Apr 12, 2015 6:17 pm ] |
jeffrodite wrote: Instead of shelling out a lot of money, all I did was just put one of my Marples into a vice and bent it to my liking. Works like a charm. I did too. Sort of on accident at first, but then I just went with it! |
Author: | murrmac [ Sun Apr 12, 2015 6:26 pm ] |
RustySP wrote: You can also take an oxy-acetylene torch to it wherever you want the bend, it will bend like butter. Just make sure you keep the torch away from the sharp end of the chisel. There is no way on earth you can heat a chisel sufficiently to bend it without the heat destroying the temper at the edge. Actually, you will ruin the temper long before the chisel gets hot enough to bend. After the chisel has been bent to shape, you can , of course, re-temper the edge if you know what you are doing. |
Author: | Cal Maier [ Sun Apr 12, 2015 9:08 pm ] |
Yes it looks as though a curved chisel would work better for scalloping braces, but.... it really doesn't work any better than a regular bench chisel. You will find in order to cut the scallop (concave area) you will have to work from either side toward the middle of the brace with either style of chisel. I find that I can control the cut much better with the bevel reversed than with it upright. I think most would find the same. But if you want to spend more money..... go for it. Cal |
Author: | meddlingfool [ Sun Apr 12, 2015 9:55 pm ] |
Upside down chisel for me too. |
Author: | RustySP [ Sun Apr 12, 2015 10:31 pm ] |
There is a way and I have done it exactly like I stated. If there was any harm done at all it was not even noticeable and by the way it was a Northern Tools crappy China chisel so who cares anyway since it is a very seldom used tool but still it does the job. Having said this, I wouldn't modify a pricey tool like this, there are too many cheap tools out there to experiment with. |
Author: | flounder [ Mon Apr 13, 2015 1:16 am ] |
Hi Cablepuller, I bought the Two Cherries curved chisels from Axminster, thinking as you are to use them for braces, but I never do! Like everyone else it is an upside down regular chisel or a veritas palm plane |
Author: | Jim Kirby [ Mon Apr 13, 2015 7:17 am ] |
meddlingfool wrote: Upside down chisel for me too. This verges on religious discussion ![]() Both ways work (curved chisel, upside down bench chisel) I tend to lean towards the curved chisel. There, I've weighed in with my vote on a choice that has no right answer. ![]() (or, I should have said, two right answers) |
Author: | Colin North [ Mon Apr 13, 2015 7:33 am ] |
OK, I'll throw in my $0.02. If you're so strapped for cash, save yourself a tenner and get a set of these - prep them as he shows. https://www.youtube.com/watch?v=Ki8tt-VjwqI |
Author: | Michael.N. [ Mon Apr 13, 2015 7:42 am ] |
I bought a set of those chisels. Turned one into a belly chisel. They are a bit crude but who cares about the 'lands' when it's not important? The steel seems perfectly good to me. |
Author: | SteveSmith [ Mon Apr 13, 2015 9:29 am ] |
Colin North wrote: OK, I'll throw in my $0.02. If you're so strapped for cash, save yourself a tenner and get a set of these - prep them as he shows. https://www.youtube.com/watch?v=Ki8tt-VjwqI Nice common sense approach in that video. For the OP's £20 should be able to get some decent chisels and everything needed to sharpen them well enough to do the job ![]() |
Author: | Ruby50 [ Mon Apr 13, 2015 7:01 pm ] |
Saw a video of Dana Bourgois (sp??) voicing a top, and he used a curved chisel and a small finger plane, but he used the chisel upside down - best of both worlds? Ed |
Author: | Jimmyjames [ Tue Apr 14, 2015 2:50 pm ] |
RustySP wrote: You can also take an oxy-acetylene torch to it wherever you want the bend, it will bend like butter. Just make sure you keep the torch away from the sharp end of the chisel. This is not a good idea. With heat you'll ruin the temper and the blade won't stay sharp. You can put the temper back in it but it will take you considerable learning and expense to master the process. If it were easy everyone throughout history would be Smiths equal to the Samauri but they're not. Also when you heat metal you alter the chemical structure of it and weaken it. Best to do it once and leave it alone. -j |
Author: | RustySP [ Tue Apr 14, 2015 3:02 pm ] |
Listen, you are are over thinking this a bit. I don't pour buckets of heat on a chisel, I put a very small, very hot flame a good distance from the edge such that the edge doesn't change color. I'm not a sword maker but my day job is metal working. |
Author: | Colin North [ Tue Apr 14, 2015 4:14 pm ] |
![]() Sorry, couldn't resist it. |
Author: | Cal Maier [ Tue Apr 14, 2015 8:42 pm ] |
"Saw a video of Dana Bourgois (sp??) voicing a top, and he used a curved chisel and a small finger plane, but he used the chisel upside down" My point exactly. Why not use your money to buy a small finger plane - You'll get a lot more use out of that than you will out of a curved chisel (unless you don't own any chisels yet.) Cal |
