Ivoroid binding with marquetry pufling. http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=45403 |
Author: | roby [ Sun Mar 22, 2015 4:13 am ] |
Post subject: | Ivoroid binding with marquetry pufling. |
Is the best way to do this,tape in place then wick in thin CA glue? Opinions and other methods would be appreciated.All the best Roby. |
Author: | Haans [ Sun Mar 22, 2015 7:03 am ] |
Post subject: | Re: Ivoroid binding with marquetry pufling. |
Really have nothing good to say about CYA for celluloid binding. I use Weldon 16 and find it to be more sticky than Duco cement. CYA will wick into the purfling and turn it yellow under the finish. |
Author: | Brad Goodman [ Sun Mar 22, 2015 2:29 pm ] |
Haans wrote: Really have nothing good to say about CYA for celluloid binding. I use Weldon 16 and find it to be more sticky than Duco cement. CYA will wick into the purfling and turn it yellow under the finish. What he said. |
Author: | Quine [ Mon Mar 23, 2015 9:10 am ] |
I've used CA with ivoroid many times with no problem or yellowing. I do it just like you describe...tape in place and drop thin CA. Then hit it with the activator to get a fast cure. CA will soften/dissolve celluloid binding if left wet too long...more than a few seconds, so spray activator as you go. Get a glue pipette or syringe too, drops from the bottle tip are way too big and will wick everywhere |
Author: | roby [ Mon Mar 23, 2015 1:22 pm ] |
Thanks for the advice,Hans,is Weldon 16 good for wood purfling? |
Author: | JasonMoe [ Mon Mar 23, 2015 3:54 pm ] |
I have used 3M Plastic and Emblem adhesive for Plastic and Ivoroid binding. Its clear and is tough stuff. You can find it at your local auto parts store. |
Author: | Haans [ Tue Mar 24, 2015 7:31 am ] |
Roby, Weldon 16 is for the binding. I use white/yellow glue for purfling. |
