It is currently Tue Aug 19, 2025 2:04 am
PostPosted: Wed Mar 18, 2015 5:45 pm
Last Name: Beaver
City: Lake Forest
Hi,
I will be attempting my first Nitro finish in a few days. I have chosen Cardinal Luthierlac.
I plan to use epoxy filler under the finish. Should I put a coat of vinyl sealer over the epoxy and under the finish or spray the nitro right on the epoxy?
Also, any suggestions as to spray schedule would be greatly appreciated.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 18, 2015 6:22 pm
I would use the vinyl sealer. It'll assure good adhesion
PostPosted: Wed Mar 18, 2015 8:33 pm
Scuff the epoxy well before spraying their sealer. After spraying a few coats of sealer, scuff it very well before spraying the lacquer.
I had a lot of adhesion issues before getting in touch with Mac. He really impressed the importance of scuffing on me, which wasn't an issue when I used McFadden.
PostPosted: Wed Mar 18, 2015 10:05 pm
Before I started using Zpoxy as a filler I communicated directly with tech support at Pacer and I was assured that their product was compatible with nitro lacquer. I use vinyl sealer as part of a complete finishing system and would recommend that practice regardless of the pore filler that is used.
Ken Cierp
PostPosted: Wed Mar 18, 2015 11:25 pm
Last Name: Beaver
City: Lake Forest
I did order their vinyl sealer. When I read the write up on lmi's page I got the impression that you didn't have to scuff the vinyl sealer if you sprayed the top coat within a half hour. Apparently that is not the way to do it.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 18, 2015 11:36 pm
I had to strip the finish twice because it peeled like a flaking sunburn when I tried to level. I'd scuff just for good measure.
PostPosted: Thu Mar 19, 2015 12:51 am
Last Name: Beaver
City: Lake Forest
James,
I think I remember you posting something about that. It would be a real bummer. After all was said and done, how did you like the cardinal?
Joe Beaver
Maker of Sawdust
PostPosted: Thu Mar 19, 2015 6:46 am
The information I got from Pacer was in regard to their Zpoxy "finishing resin" if using System Three or other I'd check with the makers. The beauty of a compatible nitro finishing system is that each layer of chemical "burns" into the previous layer. Personally, I simply would avoid using coatings that lay "on top" each other --- with scuff process or not.
Ken Cierp
PostPosted: Thu Mar 19, 2015 11:02 am
Joe Beaver wrote:
James,
I don't have the nuance to compare the final result to the McFadden I've used before, but it seemed slightly trickier to use due to those issues. I think it's a great to still have an option for lacquer though.
PostPosted: Thu Mar 19, 2015 11:39 am
I am pretty sure Seagraves "Macfadden formula" instrument lacquer is still being sold -- I thought I saw it in the SM catalog.
Ken Cierp
PostPosted: Thu Mar 19, 2015 11:53 am
Last Name: Beaver
City: Lake Forest
Ken
I thought Seagrave bought the rights to McFadden. But when I google Mc fadden lacquer it comes up with a full Lawerence McFadden product line inclusing Nitro with Seagrave on the bottom of the page. One big happy family now?
Joe Beaver
Maker of Sawdust
