Help with buzz http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=40702 |
Author: | CDKeith [ Thu Jun 20, 2013 8:36 pm ] |
Post subject: | Help with buzz |
A guitar that I built for a friend has developed a buzz on the 4th string, but only when fretted at the 1st fret. It really sounds like the buzz is coming from the saddle/bridge area, but I've confirmed that the string's ball-end is firmly seated between the bridge plate and bridge pin. Any suggestions? Thanks, Chris |
Author: | Jeff Highland [ Thu Jun 20, 2013 8:44 pm ] |
Post subject: | Re: Help with buzz |
Todd Stock wrote: Back-buzz...check the non-speaking portion of the string, as well as adjacents. I don't think you can get Back Buzz happening on the 1st fret....... |
Author: | twick [ Thu Jun 20, 2013 8:52 pm ] |
You might try Putting a fret rocker on the second fret. They always seem to sound like they comming from the bridge. |
Author: | theguitarwhisperer [ Fri Jun 21, 2013 1:36 am ] |
Very often I've seen kinks in the strings from pressing too hard or being bumpe, or it's a new string that was unwrapped incorrectly. If the kink is right over the fret it will cause noting out. Changing the string or rubbing the string firmly with a screwdriver handle will fix it it if that's the case. |
