First ukes http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=32471 |
Author: | Parser [ Wed Jun 08, 2011 7:20 am ] |
Post subject: | First ukes |
I've just been wrapping up my first couple of ukes and thought that I would share my experiences a bit. First, a few pics: ![]() ![]() ![]() ![]() This one has a red spruce top, koa back and sides, EIRW binding & fingerboard, and a mother of pearl palm tree. The rosette is 3 pieces of koa with a b-w-b border. I got a whole pile of red spruce uke tops when I worked at PRS - they were too small for guitars, and fortunately for me, Paul had not been bitten by the uke bug ![]() The plan is one that I drew. I initially intended it to be a tenor uke, but I've apparently made the body more of a concert size (although it is a tenor scale). I found some info that said that tenor bodies were typically 8.25" wide and it turns out that is a bit smaller than normal. This one fit best in a concert uke case (lanikai makes some decent cases). Best practice for new body shapes seems to be to buy a case first, and then to design the instrument to fit a standard case...(duh)! I'm a big proponent of voicing guitars, but on a body this small, I can't really say that I feel the builder has much latitude to really tune the top. I think this would have been another advantage of building to a wider/longer body shape - increased "voiceability". The necks were set pretty similarly to how I would set a guitar neck, with approximately 1/16" to 1/8" of clearance between a straight edge on the frets and the top of the bridge. It sounds nice and is a ton of fun to play! Guitars feel huge after playing these little things so much...! Thanks, Trev |
Author: | Colin North [ Wed Jun 08, 2011 7:45 am ] |
Post subject: | Re: First ukes |
That's some serious instruments you got there, thanks for sharing. Got to love Koa! |
Author: | GCote [ Wed Jun 08, 2011 8:19 am ] |
Nice Ukes, I did 2 last year and hae another for this year... Where did you get the case?? Gary |
Author: | ernie [ Wed Jun 08, 2011 9:37 am ] |
trev what joint did you use ?? bolt on butt glue ?? and what is em 6000, finish ?? |
Author: | Parser [ Wed Jun 08, 2011 9:47 am ] |
Hey Gary - the case is a Lanikai concert uke case - you can buy these from a lot of places online. It's a hard shell with a cloth exterior - they run about $35. Ernie - I screwed and glued with a mortise & tenon joint. One of them has a threaded insert and for the other, I just used a quality wood screw. These things are so small that they are the one instrument on which I think it *may be* practical to do a compound dovetail...it's hard to get your fingers plus a tool in those little tiny soundholes...! Trev |
Author: | Mike Dotson [ Wed Jun 08, 2011 11:42 am ] |
Looks great! What fret wire size did you use? |
Author: | Quine [ Wed Jun 08, 2011 12:13 pm ] |
Nice Uke. I like that bridge design |
Author: | Parser [ Wed Jun 08, 2011 1:17 pm ] |
I used the standard fretwire from LMI...the bridge is also from LMI. I duplicated this bridge design for the mesquite one that I'm completing now. Trev |
Author: | Michael Smith [ Wed Jun 08, 2011 11:35 pm ] |
Hey Parser beautiful looking uke. Make sure you come and join us guys that hang out at ukulele undergound as well. |
Author: | unkabob [ Thu Jun 09, 2011 11:14 am ] |
The standard fretwire that Hana Lima use is size # 147. It is a little smaller but larger than mandolin fretwire. Bob ![]() |
Author: | Parser [ Thu Jun 09, 2011 8:36 pm ] |
Thanks guys - I'll definitely check out ukulele underground. I'm all jigged up, so I may as well make a few more... ![]() |
