Stainless Steel Slats for Fox bender
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=32020
Author:  segovia [ Thu Apr 28, 2011 2:09 pm ]
Post subject:  Stainless Steel Slats for Fox bender
I decided to replace my spring steel .46mm steel slats with 420 stainless steel - the only thickness I could get was .5mm
I have not used them yet but the .5 looks a little stiff in comparison to the .46mm of the steel -
What are you using out there - is .5mm an the thick side ?
Author:  Alain Moisan [ Thu Apr 28, 2011 4:11 pm ]
Post subject:  Re: Stainless Steel Slats for Fox bender
I'm using the plates LMII sells. I believe they're .025'' (0.635 mm). So you should be fine with 0.5 mm.
Author:  segovia [ Fri Apr 29, 2011 1:28 am ]
I passed e through my bender and it seemed OK, the acid test is when I make a sandwich of the the other and the blanket.
.635 seems heavy to me - thanks for the info
