It is currently Sat Aug 23, 2025 1:52 am
 Post subject: Re: Bandsaw blades
PostPosted: Sun Apr 24, 2011 9:53 pm
First name: Mark
City: Concord
I have been using http://www.woodcraftbands.com/index.htm for the past 6 years and have been very happy with the price and service. John carries multiple brands of blade stock. Call and tell him what you want to do and he will match the best material for the job.
PostPosted: Sun Apr 24, 2011 10:04 pm
Try Hastings Saws http://www.hastingssaws.com/. Great welds on Lennox bimetal blades. Excellent blade life.
Ken Franklin
clumsy yet persistent
PostPosted: Mon Apr 25, 2011 1:34 am
Last Name: O'Melia
City: Huntsville
State: Alabama
As always... super happy with my Laguna blades. All of them.
If you want special access deals, PM me for info.
PostPosted: Mon Apr 25, 2011 7:27 am
First name: Big
Last Name: Jim
I sell Diamond saw works blades , Hard edge flex back . I have alot of customers that like them and its what I use as well . That having been said , I dont know how you fellas would rate them .
PostPosted: Mon Apr 25, 2011 8:11 am
Filippo Morelli wrote:
It seems that, forever, they ran a "Buy 3 get 1 free" deal. Well I can no longer find it on their web site (which has also been rewritten). Forever gone?
Filippo
FYI, I was told directly by them when I tried to use it a second time that it was a one-time deal for new customers only. That was a couple years ago, they could have done away with the deal altogether.
PostPosted: Mon Apr 25, 2011 9:56 am
Filippo,
Ditto what Ken Franklin said. Folks around these parts and beyond have been using them for years including the College of the Redwoods.
Give them a call and they will set you up for trouble free sawing.
Link
PostPosted: Mon Apr 25, 2011 7:22 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Get mine from here http://www.custombandsawblades.com Made to order from Starrett band stock. Price isn't bad.
Brian
Brian
PostPosted: Mon Apr 25, 2011 7:55 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Filippo,
What are the Olson blades doing or not doing? Or do they just dull too fast? I've always considered them ok, not great but ok, relatively cheap & in stock at my local Woodcraft.
Kevin Looker
I'm not a luthier.
PostPosted: Mon Apr 25, 2011 8:46 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
what is your most used size???? I need to order a new blade for my 14in craftsman and cant decide between a 3/8 or 1/2 in blade ??..and how many teeth per inch??? Not using for resaw just general woodworking ...
MK5acoustics.com
PostPosted: Mon Apr 25, 2011 9:22 pm
First name: Big
Last Name: Jim
Most common user is 3/8" 6T Skip blade . Hook tooth will cut faster and last longer but itsa rougher cut .
PostPosted: Tue Apr 26, 2011 5:21 am
For non-resawing I find that three blades do everything for me. All are M42 bi-metal blades, can't for the life of me understand why anyone would buy anything else. They stay sharp so much longer, they cut superbly and give a better finish than carbon steel blades. Over their life they also work out much, much cheaper.
I use a 13mm 6-10vp, 10mm 6 and a 6mm 10-14vp. I usually get Bahco or Hakansson blades welded to length, but have also used Lennox, Starrett and Morse.
PostPosted: Tue Apr 26, 2011 6:38 am
Filippo for non-resawing I use the Lenox bi-metal blades. They last a long time.
PostPosted: Tue Apr 26, 2011 8:29 am
First name: Big
Last Name: Jim
Bi metal blades will hold edge alot longer , they are more expensive . I can see where a one or two man shop would prefer them , however most of the production shops I sell two dont want to spend the extra $ . Go figure idunno
PostPosted: Tue Apr 26, 2011 11:27 am
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
For the non resaw blades you ask about, I recommend that you learn to make your own blades from coil stock. I have sold Hakannson coil stock for over 20 years and shown many woodworkers how to easily silver solder their own blades. I'm not trying to sell you anything other than the idea here. For your 142" blade, a 1/4" width would cost you less than $9.00. I'm sure someone sells coil stock locally where you are. The smallest quantity available is usually 100', but once you have it around you will start changing your blades much more often. You'll enjoy having sharp blades. Silver soldering is fast and easy. Breaks far less often than welded blades. You can get a starter silver solder kit, often sold as blade repair kits, from places like Woodcraft for $30.00 or less. The starter kit has enough solder to do many, many blades. Itis a great skill to have too. Enjoy your building!-Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Tue Apr 26, 2011 1:09 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
In terms of the Olson blades, I've had good luck with the 1/4" 4T skip blades as long as I'm not cutting anything too thin or trying to scroll too tight. I find the skip tooth blades easier to control when trying to cut smooth curves.
I don't like the regular tooth Olson blades.
Kevin Looker
I'm not a luthier.
PostPosted: Tue Apr 26, 2011 3:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Now this IS interesting. What would be the largest size one would go up to with this technique? And, after soldering, does one have to grind the joint? And finally, what are the coil costs? (typically)
PostPosted: Tue Apr 26, 2011 4:13 pm
First name: Mark
City: Concord
Here's a tutorial from Bob Vaughan:
http://owwm.org/viewtopic.php?t=33506
PostPosted: Thu Apr 28, 2011 1:26 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Mike, I've always done all my grinding on one of my belt sander machines. I double up the blade and make a scarf joint at the ends. After soldering I smooth both sides of the blade and the back. It is easy, fast, and does not have to be very perfect. I normally cut up a 100 foot roll into the appropriate lengths and then solder a bunch of them. Including the sanding I can do 8 or 9 blades in an hour. Been doing it successfully for 25 years or so. Blades very, very seldom break. I am most comfortable doing blades 1/2" or less, but did recently do some 1" blades for a friend and they are working. For 1/2" and under, a propane torch works fine. For the 1" I stepped up to a MAP gas torch. Coil stock prices can very quite a bit. I sell what I think is the very best coil stock, Hakannson, because it has hardened teeth. Timberwolf blades were actually made by Hakansson, but Suffolk had it contracted so that only they could sell the Timberwolf line. I don't know if Hakannson is still the producer. I sell Hakannson 1/4" x 100 foot rolls for $77.00 and you should be able to find something like that in your neck of the woods. I also sell bi-metal, but really don't think it is worth the cost for general shop work. For serious resawing I use stellite and carbide tipped blades from Woodmizer and Lenox. You can't beat them for smooth resawing.
Users browsing this forum: Colin North, Michaeldc and 8 guests
