It is currently Sat Aug 23, 2025 1:51 am
PostPosted: Thu Apr 28, 2011 2:09 pm
Last Name: Charnock
Country: UK
I decided to replace my spring steel .46mm steel slats with 420 stainless steel - the only thickness I could get was .5mm
I have not used them yet but the .5 looks a little stiff in comparison to the .46mm of the steel -
What are you using out there - is .5mm an the thick side ?
PostPosted: Thu Apr 28, 2011 4:11 pm
I'm using the plates LMII sells. I believe they're .025'' (0.635 mm). So you should be fine with 0.5 mm.
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Apr 29, 2011 1:28 am
Last Name: Charnock
Country: UK
I passed e through my bender and it seemed OK, the acid test is when I make a sandwich of the the other and the blanket.
.635 seems heavy to me - thanks for the info
Users browsing this forum: Colin North, Michaeldc and 9 guests
