Who Sells Pre-Made Solid Wood Rosette Rings?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=31814
Author:  Ron M. [ Mon Apr 11, 2011 4:05 pm ]
Post subject:  Who Sells Pre-Made Solid Wood Rosette Rings?
I'm looking for the ones that LMI sells (see the photo below) preferably in maple. LMI only has walnut, koa, and lacewood. Thanks in advance for any leads.
-Ron
Author:  jmanter [ Mon Apr 11, 2011 4:48 pm ]
Post subject:  Re: Who Sells Pre-Made Solid Wood Rosette Rings?
I make my own using the same jig i use to cut the channel.... very easy to do...
Author:  mike annis [ Mon Apr 11, 2011 5:18 pm ]
Ron,
I make my own also using jig that is used to route channel. If i could figure out how to post a picture i would. I'm technically challenged, especially when the kids are at school!
Author:  Imbler [ Mon Apr 11, 2011 6:29 pm ]
Probably a stupid question, but where do you get your wood to cut the ring from. Do you resaw from a flatsawn board?
thanks, Mike
Author:  Ron M. [ Mon Apr 11, 2011 8:03 pm ]
mike annis wrote:
Ron,
Hi Mike,
When you figure out how to post a picture of your jig I would love to see It. I'm sure they are easy to make, but I just wanted something quick. I used the lmi rosettes before, but this time around I would like maple which they don't make
Hi jmanter,
What kind of jig do you use? Thanks
-Ron
Author:  alan stassforth [ Mon Apr 11, 2011 8:08 pm ]
Build yourself a Wells Karol jig.
2 hours.
Very useful!
Author:  Ron M. [ Mon Apr 11, 2011 10:06 pm ]
2 hours.
Very useful!
Hi Alan,
I've been meaning to build a Wells Karol jig but never got around to doing It. Thanks for reminding me.
-Ron
Author:  John Mayes [ Mon Apr 11, 2011 11:51 pm ]
Alternatively you can use a circle cutter in a drill press... $10 and 5 minutes later.....
Author:  Gtrman13 [ Tue Apr 12, 2011 2:00 am ]
thanks, Mike
Easiest thing to do is to buy a couple of pieces that are sold as headplates, join them together and like the others have said, use the same circle cutter you use to route the channel. You could also use some scrap from a B&S set if you happen to have it lying around.
Author:  jmanter [ Tue Apr 12, 2011 5:06 am ]
I use a wells karol jig.... i buy bowl turning blanks at woodcraft and cut them into sheets and make the rosette rings from that..
Author:  Christoph [ Tue Apr 12, 2011 6:15 am ]
I have used joined bridge reinforcement plates before.
Author:  Ron M. [ Tue Apr 12, 2011 9:33 am ]
I will take everyones advice and make my own. I just ordered the LMI Rosette/Circle Cutter.
http://www.lmii.com/CartTwo/thirdproduc ... cle+Cutter
Thanks again to all,
