It is currently Fri Aug 22, 2025 1:10 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
PostPosted: Fri Apr 01, 2011 5:06 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Hi again, sorry for the posting spree.
this time it goes like this: i´m thinking of buying a cheap drum-sander, and was wondering if the JET 10-20 ( http://www.axminster.co.uk/jet-jet-10-2 ... prod32808/ ) is good enough (size-wise) or if it is too modest, and i should go for the 16-32 model ( http://www.axminster.co.uk/jet-jet-16-3 ... prod33027/ ).
thanks in advance.
Miguel.
PostPosted: Fri Apr 01, 2011 5:08 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've used a 10-20 for several years.
First name: Corky
Last Name: Long
City: Mount Kisco
I have the 10-20 and like it fine. If you want to thickness joined tops you can, although the drum has to be adjusted dead on perfect or you'll put ruts in the middle of the top. Mine's adjusted pretty well.
PostPosted: Fri Apr 01, 2011 5:18 pm
First name: Stuart
Last Name: Gort
I have a brand new Jet 10-20 for sale. I doubt there is an hour of running time on it. PM if you like and I'll get some pics to you.
It's a fine unit but I like the cnc better for planing.
:) .... just read you were from Portugal...sry.
StuMusic
PostPosted: Fri Apr 01, 2011 6:32 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I have a 10-20 and like it fine. However, I wouldn't try to sand a joined top with it. Were I buying again, I'd spend the cash for the wider machine.
Chris.
PostPosted: Fri Apr 01, 2011 6:56 pm
I sand joined plates all the time with the 10-20. It's just a matter of setting it up precisely. However, if I had the room, I'd buy a bigger sander. It takes twice the time with a 10-20, something to keep in mind.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Apr 01, 2011 7:04 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
ok, thanks. i think i´ll go for the 10-20.
Miguel.
PostPosted: Fri Apr 01, 2011 9:32 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I have a 10- 20 and like it just fine, you do have to tweak it...dont try to sand too much at a time or you will pay the price in sandpaper rolls!!!! the belt tracking can be a little pain as it seems to wander and if you aren't carfull you will end up tightening it too much and the replacement tracking belts are 26 bucks!!!!! you may wonder how I know that duh ..If I had the space I would probably consider the 16=32 but you will need to weigh the additional cost against what you are looking for in a sander...if price and room are not a factor by all means go for the 16-32... I do like Jet tools!!!!!!
MK5acoustics.com
PostPosted: Sat Apr 02, 2011 1:04 am
I've got the 22-44 and love it. I'd much rather have something a little too big most of the time, than once in a while not have big enough. Two things to consider though. First, is the foot print. With the frame and motor and stuff, this things are much bigger than you'd think. Double check the size before you commit. Second is the operating cost. The bigger machines use much more paper so it is more expensive to reload. And, if I remember the feed belt on my was close to 100 bucks? Craigslist wasn't quite the deal I thought it was that day.
Still, wouldn't get rid of it except for an upgrade.
Mike Lindstrom
PostPosted: Sat Apr 02, 2011 9:54 am
First name: Miguel
Last Name: Bernardo
Country: portugal
space is, indeed, a problem. even more so than money (the difference between them is not that much). another problem is that the 16-32 model is ready for dispatch at axminster and the 10-20 is out of stock ATM. but reason must prevail, i´ll go for the 10-20.
thanks all.
PostPosted: Sat Apr 02, 2011 10:23 am
You'll be pleased, it's an excellent and very precise machine. I make my purfling sheets with it and can get even .010" curly maple without problem.
As with all drum sanders, it is not possible nor reasonable to try to take too much material in one pass. It is not a planer, but with 25 grit sandpaper it is possible to hog off .010" per pass, depending on the material.
Laurent Brondel
PostPosted: Sat Apr 02, 2011 4:28 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Thanks for the answers.
Laurent, is it easy to find 25 grit paper for the 10-20? in a quick search the coarser i was able to find was 60 grit.
cheers,
Miguel.
PostPosted: Sat Apr 02, 2011 4:43 pm
cheers,
Miguel.
I UK Jet used to supply 36 grit as an optional extra with the sander if that's any help
PostPosted: Sat Apr 02, 2011 5:35 pm
My local woodcraft stocks the 36 grit in box of three and rolls. Haven't seen 25 grit. If you've got a lot to hog off, I really like my safety planer to get close, then off to the sander to clean it up and creep up on what I really want.
Mike Lindstrom
PostPosted: Sat Apr 02, 2011 8:35 pm
First name: Nelson
Last Name: Palen
Miguel, the answer is quite simple. Get both machines!
PostPosted: Sun Apr 03, 2011 8:46 am
Todd Stock wrote:
I like my 10/20, but it does tend to be a little frustrating when the circuit breaker kicks off under even moderate loads.
Todd, I had that problem in my old shop when I was running the 10/20 (and dust collection) out of a single 15amp circuit. In my new shop I have 4 different circuits, the 10/20 runs on a 20amp circuit, the collector on a 40amp/240v circuit, and the 10/20 breaker has yet to kick off after a year and a half. And I use it every single day.
Laurent Brondel
PostPosted: Mon Apr 04, 2011 8:25 am
Todd Stock wrote:
I should have been clearer - I was talking about the integral breaker on the sander, versus the breaker on the line. For a time, I was convinced that the breaker was undersized for the current; however, the amp draw at blow is right at rotor locked FLA.
Yes, I understood Todd. I am also talking about the breaker on the 10-20, not the one on the fusebox. Once again, since I have my new shop with 4 different circuits, the 10-20 breaker hasn't popped. I am no electrician but I suspect the 10-20 peaks wildly in what it asks from the line, and when it doesn't get it fast enough, the 10-20 breaker pops.
I have all lights on a 15amp line, various power tools on two 20amp lines and a 240v/40amp line for the dust collector. When using the 10-20 it is alone on the 20amp line. Probably overkill, but it works.
In my old shop the 10-20 would kick off at the slightest occasion, but I had a lot of things on the same circuit, frustrating since the 10-20 breaker would pop way before (and much more often) than the one in the fusebox (rarely). Same 10-20 BTW.
Laurent Brondel
PostPosted: Mon Apr 04, 2011 12:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
The 10-20 is a fine machine. I used it to build a harp guitar which is pretty wide. Yet, I would have liked a wider machine. If you can afford the price, I would go with the 16-32. Wide enough for many designs. I ended up with the 22-44, that is an awesome machine. There does appear to be an issue with overheating in the 10-20. I experienced it. Too many theories (as already mentioned). Mine is, the motor is not quite up to doing wide sets. There is a link in the tutorial section for aligning (leveling) the head. Take a look at it.
PostPosted: Mon Apr 04, 2011 1:28 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Laurent,
What can happen is, if you are on an overloaded circuit, the voltage drops, but the amps go up to supply the power the machine is demanding. Unfortunately, the internal circuit breaker (like all the ones I know) senses amps, so it shuts down. I'm not saying some of the machines may not have weak breakers, but a dedicated circuit will help. I'm using my 10-20 on a dedicated 20 amp circuit, and have never had the internal breaker blow.
Anyway, whether I just got lucky with my 10-20, or the 20 amp circuit is helping it; I think it is a real workhorse. I thought it was actually pretty easy to level the drum so I can sand wide pieces without a ridge. It did - really - need adjusting, though, it was way unlevel out of the box.
My shop is just whatever is left in the garage with both cars parked in it so the smaller footprint of the 10-20 was important to me.
PostPosted: Mon Apr 04, 2011 4:30 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
now you guys are making me scared... hope my 10-20 will be a well behaved beast. here, kitty...
cheers,
Miguel.
PostPosted: Mon Apr 04, 2011 4:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Filippo,
I have heard every explanation under the sun for this. And the 10-20 is definitely plagued by it. I run my 22-44 on the same circuit and have never had this problem. And, the motor never gets hot either. I just think there is something about the sizing of that motor and the task it is expected to do. Something is out of sorts. Whatever it is, bypassing the thermal circuit seems a bad idea to me. Maybe this falls under the catagory of "it is what it is". I have never heard of anybody having this problem all of the time. Just occasionally. Me? When I was really working the machine.
PostPosted: Tue Apr 05, 2011 4:09 am
I'm not very savvy about electrics, but just a possible clue to the overheating/trip out problems mentioned.
I use mine in UK, on 220 volts, and have never had it trip out or overheat (despite 3 years of abuse!), but of course it may be a different motor, it is 1200 watts input, about 5.5 amps.
PostPosted: Thu Apr 07, 2011 12:38 am
First name: Tom
Last Name: Dl
Has anyone tried the Grizzly 10-20.
I used to own the 16-32. I never could be bothered to adjust it, I just used the tapered board approach, which had a lot going for it. I could see that working with a 10, but it might be a little more delicate controlling the offset. Anyone try it?
PostPosted: Thu Apr 07, 2011 9:10 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Not sure what you are asking. Aligning the drum to the platten is not difficult at all. And it is well worth the effort. Can be done in as little as 10 minutes.
PostPosted: Thu Apr 07, 2011 5:24 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Filippo Morelli wrote:
Aligning is not that bad, though on the bigger machines I have to say that the adjustment setup is not an adjustment setup at all - obviously no one designed the machine to be adjusted, per se. But that said, the taper can work well for guitars :-)
Filippo
...As long as one has the correct taper... right? Otherwise you have a problem. As per my experience, and it only concerns the Performax/Jet 10-20 and 22-44, the alighment procedure is 95% the same. Differences exist, but most folks can see them quite easily. So if by "bigger" machines you are referring to some other machines, I would have to yield to your knowledge there.
Users browsing this forum: No registered users and 43 guests
