Vintage guitar golpeador removal
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=30818
Author:  jlneng [ Sun Jan 23, 2011 4:35 pm ]
Post subject:  Vintage guitar golpeador removal
Hello All,
Was thinking of buying a vintage 61 flamenco but it has 1 problem. Someone glued on a white golpeador on 1 side with hide glue, and the guitar has a clear golpeador on the other side. The guitar has a spruce top and is french polished. Is removing a golpeador glued on with hide glue a risky proposition with regards to damaging the top under it? I have removed a couple of clear mylar golpeadors with a heat gun and goop be gone with no problems but this I suspect is a far more complicated project that I would have done by a professional. Thanks....
Author:  Mike Collins [ Mon Jan 24, 2011 2:18 pm ]
Post subject:  Re: Vintage guitar golpeador removal
White meaning plastic or wood?
I would gently feel under it with the same tool I use for bridge removal
a thinned and rounded edge putty knife.
Hide glue can separate easily if used on plastic.
Go slow.
Author:  jlneng [ Wed Jan 26, 2011 9:04 pm ]
Wood....
