Bloodwood Binding Considerations http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=30021 |
Author: | Ian Cunningham [ Sun Nov 21, 2010 9:24 pm ] |
Post subject: | Bloodwood Binding Considerations |
I'm contemplating my next build and I like the idea of Bloodwood binding on a Walnut/Englemann Spruce instrument. I'm a bit concerned about the color "bleeding" (pardon the necessary pun ![]() |
Author: | old man [ Sun Nov 21, 2010 11:03 pm ] |
Post subject: | Re: Bloodwood Binding Considerations |
I've used bloodwood several times and never had any bleed problem. I haven't used it with walnut, but it is my favorite on koa or tasmanian blackwood or curly white oak. On walnut I like curly maple. Ron |
Author: | theguitarwhisperer [ Sun Nov 21, 2010 11:25 pm ] |
I bound a spalted maple fretboard with bloodwood, no bleeding. Padauk bleeds, bloodwood doesn;t seem to in my experience. |
Author: | Chris aka Sniggly [ Sun Nov 21, 2010 11:26 pm ] |
Ian - IF your finish is going to be Danish Oil then you won't need to seal the bloodwood. Not enough solvent in that stuff to cause the bleeding you speak of. BUT - do a test anyway. White cloth dabbed in some Danish Oil...rub it on a strip of bloodwood and see how red the white cloth gets...apply it the same way you would apply to any other piece of furniture or otherwise...but don't try and MAKE it bleed. BTW I think Waterlox sealer and finish would be a better choice but that's just me thinking out loud. Chris |
Author: | JasonMoe [ Mon Nov 22, 2010 3:22 am ] |
I've never had bleeding with bloodwood. Only recomendation is bending the bloodwood binding on high heat,,with little water..I bend on a pipe..Get it good and hot..some pieces depending on how its cut or something just snap easily. |
Author: | Ti-Roux [ Mon Nov 22, 2010 7:24 am ] |
If you have runont, it will break. If you have nice Q-sawn pieces, wihtout runout, then it will bend easily, with lot of heat and a bit of water. +1 with shellac sealing before anything. Checkout your glueing too. If you glue with CA, you'll have more bleeding issues than with PVA or Hide glue. Francis |
Author: | GregG [ Mon Nov 22, 2010 7:36 am ] |
Never had any bleediing issues with bloodwood either, bending has been straightforward too, nothing fancy or different, bent easy for me on numerous occasions. |
Author: | Bailey [ Mon Nov 22, 2010 9:48 am ] |
Love the stuff. Bent easily for me and looks great. No bleeding with me.....not that a band aid wouldn't take care of. kent |
Author: | alan stassforth [ Mon Nov 22, 2010 10:15 am ] |
I recently bought a nice piece of bloodwood from the local hardwood store' ripped it into bindings, broke off a piece, and found pretty major runout. I broke the first try, then made 8 more pieces succesfully, for 2 projects, 1 with serious tight bends. I used a terry towel soaked with water over a hot pipe. Steamy affair! It turned to rubber. I'll let ya know if it bleeds. Gonna be a while though. |
Author: | Ian Cunningham [ Mon Nov 22, 2010 10:23 am ] |
Looks like I'll be okay then. Thanks guys ![]() |
Author: | Tim L [ Mon Nov 22, 2010 11:45 am ] |
I've had bleeding problems with Bloodwood. Bled when I wiped on a coat of shellac, of all things. It was totally unexpected and stained the curly maple purfling next to it a light pink in the flame. Took a bit of sanding to remove ![]() Tim |
