Glueing soundboard and back
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=29976
Author:  MikeG [ Fri Nov 19, 2010 12:23 am ]
Post subject:  Glueing soundboard and back
I'm getting ready to glue the soundboard and back on and I am thinking about using my go bar press. Will that work and if you don't think it will what would be better?
Author:  Jeff Highland [ Fri Nov 19, 2010 1:22 am ]
Post subject:  Re: Glueing soundboard and back
Yes, I do all mine that way.
IMHO it is a great way to go
I use a piece of 3mm thick mdf cut to the outline of the top or back to protect it against damage from slippage.
Author:  Terence Kennedy [ Fri Nov 19, 2010 8:45 am ]
I started with clamps, then a modified spool clamping technique with threaded rods in my mold, and finally go-bars. I've used the go-bars for five or six years and would never go back to anything else.
Author:  devincox [ Fri Nov 19, 2010 11:05 am ]
I am on my first I didnt have enough clamps and didnt want to buy them, didnt want to spend the time making them, so I bought some kite rods and cut them in half. I actually just use the tray underneath my bench as my gobar deck, and it worked perfectly. I adjust the height with a piece of plywood under my workboard to vary the pressure.
Devin
Author:  woody b [ Fri Nov 19, 2010 8:00 pm ]
Go bar's here
Author:  MikeG [ Fri Nov 19, 2010 9:36 pm ]
Thanks for the responses, I'm glad to hear the go bars work. I like the idea of cutting the piece of wood to use between the go bars and the top and back.
