"Goof-Off" Remover http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=29706 |
Author: | David LaPlante [ Fri Oct 29, 2010 6:59 pm ] |
Post subject: | "Goof-Off" Remover |
I just tried cleaning my bending iron with this stuff. It really did a good job of removing all the old blackened and burnt rosewood resin. A "scotch brite" pad was helpful in additionally scrubbing the aluminum heating element really clean. |
Author: | WaddyThomson [ Fri Oct 29, 2010 10:02 pm ] |
Post subject: | Re: "Goof-Off" Remover |
Good tip, David! I have some of it, but almost never use it. I try not to do any more painting than I have to! ![]() |
Author: | Daniel Minard [ Sat Oct 30, 2010 2:41 am ] |
Good tip David. I have been wrapping my iron with aluminum foil & replacing it when it gets covered in tar. |
Author: | MaxBishop [ Sat Oct 30, 2010 8:18 am ] |
Thanks for the tip, David. My bending iron is looking pretty grungy. So I will give it a try. Max |
Author: | WudWerkr [ Sun Oct 31, 2010 10:23 am ] |
Wish I woulda had "goof off remover " when the teenage sone was still at home ! |
Author: | JoeUlman [ Sun Oct 31, 2010 2:14 pm ] |
I’ve had a small can of it that’s lasted for over 20 years now. It works great… but… I will not use it inside the house or without protective gloves due to the extremely strong organic vapors it gives off. They have a milder version of the stuff with less fumes but it doesn’t work nearly as well. Joe |
Author: | David LaPlante [ Mon Nov 01, 2010 7:43 am ] |
I know what you mean Joe, I should have mentioned that I did the work outside. I'm guessing that this is mostly mneral spirits but there are additional solvents which seem to give it more "kick". Good ventilation is a must with this stuff. |
Author: | jeb98 [ Mon Nov 01, 2010 11:21 pm ] |
I used to use this stuff when I worked as a painter over the summers in college, and it definitely worked great for removing paint and residues, but I have to agree with the prior posts that you should definitely not use it indoors and without a good mask. It definitely gave me some sort of horrible buzz after using it indoors for any length of time, and I remember the health warnings written on the side of the bottles being pretty serious in terms of it's potential negative health affects. I personally stay away from it. |
