Theory Behid Free Plate Tuning using Chladni Mode Patterns
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=29612
Author:  J2guitarII [ Fri Oct 22, 2010 7:21 pm ]
Post subject:  Theory Behid Free Plate Tuning using Chladni Mode Patterns
A discussion of why using the ring-and-a-half Chladni mode pattern, while shaping braces, will improve the sound (volume) of the guitar is attached. Although differential equations are used to show how the stiffness to mass ratio plays and important roll in establishing the necessary isotropic properties, no math skills are required. The use of the ring-and-a-half mode pattern is used to confirm the existence of isotropic properties.
Author:  Chris Paulick [ Fri Oct 22, 2010 8:11 pm ]
Post subject:  Re: Theory Behid Free Plate Tuning using Chladni Mode Patterns
Is there a question in there?
Author:  CharlieT [ Fri Oct 22, 2010 9:34 pm ]
Jack - it sounds like you intended to attach a file but it didn't come through. I for one am very interested in the topic though. :D
Author:  meddlingfool [ Fri Oct 22, 2010 10:06 pm ]
Me as well!
Author:  Parser [ Sat Oct 23, 2010 10:48 am ]
Wood is orthotropic......
Author:  Bob Garrish [ Sat Oct 23, 2010 3:33 pm ]
A braced top, in many ways, is closer to isotropic.
Author:  J2guitarII [ Sun Oct 24, 2010 12:23 am ]
I uploaded the attachment but I don't know what happened to it. This web site showed it uploading. Any Suggestion of how to upload an attachment would be appreciated.
True, wood is anisotropic the equation for harmonic motion requires isotropic properties for efficient harmonic motion. We use and shape the braces to achieve this result using the ring-and-half mode pattern to let us know when we have succeeded.
Author:  evanmelstad [ Sun Oct 24, 2010 12:31 am ]
Is it a word document? I don't think you can attach word docs here.
Can you save it as a PDF?
Author:  J2guitarII [ Sun Oct 24, 2010 1:18 am ]
Yes, it is a Word Doc. I will try to convert it to PDF.
If anyone wants to view the whole paper (6 pages with photos and math), send me a request in an email to: J2guitar@aol.com and I will email the paper to you in a return email.
Author:  J2guitarII [ Sun Oct 24, 2010 1:44 am ]
PFD was not available and this site does not accept HTML.
Here is another try at a Word doc.
The extension doc is not allowed on this site. I'm stuck, send me an email at J2guitar@aol.com for a copy of the paper.
Author:  Bob Garrish [ Mon Oct 25, 2010 10:40 am ]
Here is a PDF copy of Jack's paper:
Author:  Fred Tellier [ Mon Oct 25, 2010 10:58 am ]
Thanks for posting the pdf Bob
Fred
Author:  J2guitarII [ Thu Oct 28, 2010 5:38 pm ]
This is a repost with the PDF File attached.
Author:  Hupaand [ Thu Oct 28, 2010 10:03 pm ]
I'm still waiting for someone to say, 'If you get such-and-so shape on your pattern, then take some off of the brace at thus-and-so point.' Guys seem to be saying, 'Experiment around with your bracing until you get a circle and a half.' Of course, I'm missing something. I wonder what.
Hugh
Author:  muthrs [ Fri Oct 29, 2010 6:53 am ]
Hugh, if only it were that easy. It is hard to predict how shaving braces will affect the pattern.
For example, I was building a cutaway and braced it up before cutting out the excess plate for the cutaway. I was having a hard time closing the ring and decided to stop and go with it. I then cut off the cutaway portion and the ring closed beautifully. Go figure.
It is easier however to get good mode shapes with certain bracing patterns, i.e. symmetrical bracing patterns are much easier.
Author:  Alan Carruth [ Fri Oct 29, 2010 1:23 pm ]
Hugh wrote:
"I'm still waiting for someone to say, 'If you get such-and-so shape on your pattern, then take some off of the brace at thus-and-so point.'"
If you guys would all build things in exactly the same way we might be able to do that. We could just specify a plan, and make everybody stick to it, and that should work.
Well, maybe, if we could specify wood properties like we can those of metal for machines. oops_sign
And no cheating: when the plan says .120" then you'd better be at .120" or the Plate Tuning Police will be on your case! Best get your calipers calibrated, boy. Watch the humidity, too! :twisted:
In short, there are too darn many variables involved. It's a _little_ easier with violins, where the structure is more standardized. Even there, changes in arch height and shape can alter the way things respond.
Over time, as we gain more experience with this, we'll start to find some guidelines that will help. One thing that will make this go a lot faster is if people will share their experiences.
Author:  J2guitarII [ Fri Oct 29, 2010 6:11 pm ]
RE: Where to start carving to get the ring mode.
The lines will move away from Stiffness and towards Mass. Carving below the bridge will close the bottom and open the sides. Carving above the bridge will close the sides and open the bottom.
See Introduction on posted paper "The Theory Behind Freeplate Tuning using the Chladni Mode Patterns"
Scroll to the post above.
Author:  Hupaand [ Sat Oct 30, 2010 12:01 pm ]
Thanks, Jack. I knew I had to be missing something, there is just too much interest in this subject to be otherwise. I had read that intro and missed the critical sentence.
Author:  J2guitarII [ Sat Oct 30, 2010 10:57 pm ]
Take a look at the beam deflection equation towards the end of the paper to see how to manipulate the Stiffness to Mass ratio.
Author:  J2guitarII [ Tue Jan 25, 2011 2:47 pm ]
An up-to-date revised version of the paper "The Theory Behind Free Plate Tuning using Chladni Mode Patterns" can be found at www.JackJohnstonGuitarMaker.com under the "Lutherie Tab"
Also under the "Lutherie Tab" is a discussion of QE/D an indicator of performance of Guitar Plates. Q is an electronic signature in digital form of the tap tone, E is the modulus of elasticity along the grain and cross grain multiplied together, and D is the density expressed as specific gravity. Values within species can be compared to each other plate in the species.
Author:  Ian Cunningham [ Tue Jan 25, 2011 7:57 pm ]
Good ta see ya Chris
