Bridge thickness
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=29565
Author:  000lover [ Wed Oct 20, 2010 11:47 am ]
Post subject:  Bridge thickness
LMI sent a maple bridge plate that is about .125 inches thick. Is that too heavy? It's for a red spruce top dreadnought.
Author:  Alain Moisan [ Wed Oct 20, 2010 11:58 am ]
Post subject:  Re: Bridge thickness
Others my differ from opinion, but I would reduce it to about .090''-.100''.
Author:  jackwilliams [ Wed Oct 20, 2010 12:07 pm ]
It would be hard to make a determination that .125 is either too thick, not thick enough, or just right, in my opinion, without knowing the thickness of the top, and the stiffness of the top,not to mention the bracing and probably some other variables.
Author:  Colin North [ Wed Oct 20, 2010 2:21 pm ]
I'd go with about 0.10 - 0.11", but, as Alain said, others may differ.
Anyway, wood suppliers don't normally supply woods to finished thicknesses IME.
Author:  woody b [ Wed Oct 20, 2010 3:45 pm ]
It depends on the thickness/stiffness of the top, as well as the bracing and size of the bridgeplate. Just like pretty much everything else there is on uniform measurement.
Author:  bluescreek [ Wed Oct 20, 2010 3:58 pm ]
Martin uses .100 I like them about the same regardless of top thickness or stiffness
Author:  Alain Moisan [ Wed Oct 20, 2010 3:59 pm ]
I'm not sure I'm with you on this guys. How exactly do you set your bridge plate thickness based on the thickness of the top and braces? And what is the logic behind it?
Author:  Howard Klepper [ Wed Oct 20, 2010 5:16 pm ]
Too thick. .100 is plenty.
