It is currently Wed Aug 20, 2025 11:57 am
PostPosted: Wed Sep 29, 2010 2:19 pm
anybody have experience using glint or glaire as an interior sealer?
pros/cons?
any long term issues?
thanks!
PostPosted: Wed Sep 29, 2010 4:02 pm
What is Glint or Glair?
What are you trying to do? Shellac is one of the best sealers out there if you want to protect from rapid humidity changes. Outperforms all man mades that I'm aware of.
PostPosted: Wed Sep 29, 2010 4:48 pm
it's a traditional grain raiser and sealer made from egg white.
PostPosted: Wed Sep 29, 2010 5:45 pm
Again, what are you trying to accomplish? I.e seal the interior from what?
There are lots of people here who've used egg white to pore fill but I'm not one of them. Hopefully they'll chime in.
PostPosted: Wed Sep 29, 2010 6:22 pm
Actually egg white by itself is not a good pore filler. It works with sawdust, i.e., wet egg white, and sand with 220 paper, then squeegee the slurry into the pores. Takes several passes, but it does work. Colin Symonds uses the method often, and I have used it once. However, egg white is an excellent sealer, and is a good sizing agent for tops. I never thought about using it for sealing the inside of the guitar. Don't see why it wouldn't work, but it might attract dirt some. Lutes used to be finished with egg white, at least the tops were.
PostPosted: Thu Sep 30, 2010 3:04 am
I've used egg white a lot as a method of pore filling, as Waddy described, and also as a size on the top before finishing. I've used it as well when restoring original German lutes where it was often used as the only finish on the top. Making a glaire however is not needed, just used straight from the egg after separating from the yolk is fine.
To answer the original question it will work fine to seal the inside of an instrument, and has ben used for this, though if you want to seal the inside a coat of shellac is better, and less likely to attract mould.
PostPosted: Thu Sep 30, 2010 9:39 am
thanks for all the replies. you've been most helpful!
[:Y:]
Users browsing this forum: Bing [Bot] and 18 guests
