It is currently Wed Aug 20, 2025 9:45 am
 Post subject: Microplane Tools
PostPosted: Fri Oct 01, 2010 8:54 am
Last Name: Charnock
Country: UK
Have any of you had any experience of using these tools in your building ?
http://www.axminster.co.uk/microplane-shopmicroplane/
 Post subject: Re: Microplane Tools
PostPosted: Fri Oct 01, 2010 9:13 am
First name: Tracy
Last Name: Leveque
State: CO
I use the flat one to hog off material for neck carving. Works like a cheese grater and makes quick work of hogging material off of a rough neck blank. Be careful though, always move in long strokes the length of the neck as this tool will chew through material so fast!
Knew a guy that used the drill press cylinder type to hog off material, and he carved through the back of the truss rod. It just removed too much material too fast.
Good luck!
PostPosted: Fri Oct 01, 2010 9:48 am
Yes, they are fast and don't load up.
PostPosted: Fri Oct 01, 2010 9:53 am
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
I use them to carve the necks of my guitars, I love them. I have the snap in handle with the round and flat Micro planes in course and fine.
PostPosted: Fri Oct 01, 2010 10:24 am
My wife was in my shop a few weeks ago and spotted one of my microplanes and confiscated it accusing me of stealing her cheese grater. She gave it back when she saw that I used it a bit. I think she still believes that I stole her cheese grater.
PostPosted: Fri Oct 01, 2010 11:57 am
First name: Pete
Last Name: Liccardello
City: Eden Prairie
State: Minnesota
Neck Shaping [:Y:]
Peter
PostPosted: Fri Oct 01, 2010 2:22 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
They're great for zesting citrus and grating parmesan :-)
PostPosted: Fri Oct 01, 2010 4:52 pm
First name: John "jd"
City: Santa Barbara
We use them to grate Asiago over our pasta.
-jd
PostPosted: Fri Oct 01, 2010 5:10 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I use my small, cylindrical one to size out holes in my jigs (ie: bending patterns to press fit the aluminum rods) and it works like a knife through warm butter! Beth
PostPosted: Fri Oct 01, 2010 5:46 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
The inventors originally designed these tools for citrus zesting, and only later did one of them realise the potential for marketing to the woodworking industries.
I have all three, flat, square and round, and IMHO they are gimmicky, and not of industrial quality for woodworking. The flat one in particular will eventually take a kink which will render it practically useless.
Better by far to shell out the bucks for a proper set of rasps, like Nicolson, or Vallorbe-/Grobet.
PostPosted: Fri Oct 01, 2010 5:53 pm
I have both sizes of the rotary ones, and they work great. The also have a following bushing for flush cutting to a template.
PostPosted: Fri Oct 01, 2010 6:19 pm
I just got the small round rasp. I use it to form the relieved area in the head where the strings exit. Works great!
Max
Max Bishop
Brighton, Michigan
PostPosted: Sat Oct 02, 2010 8:05 am
Quote:
Impossible to sharpen, versus cheap and easy sharpening for rasps, shaves, etc.
A bit off subject but how do you sharpen a rasp?
PostPosted: Sat Oct 02, 2010 9:21 am
First name: Nelson
Last Name: Palen
I've used my flat microplane to carve about 50 maple necks and it's still sharp and cuts well.
PostPosted: Sat Oct 02, 2010 10:24 am
Never done it John, but believe it's an acid bath process of controlled corrosion. Someone will know the details.
PostPosted: Sat Oct 02, 2010 11:14 am
City: Battle Ground
I've used the flat microplane blade (without the handle) to revoice a top on a completed guitar. Easy to get it inside and easy to shave braces at just about any location.
PostPosted: Sat Oct 02, 2010 2:47 pm
"I have both sizes of the rotary ones, and they work great. The also have a following bushing for flush cutting to a template."
Where did you see the bushing for flush cutting and what is the cutting depth?
Users browsing this forum: DennisK, Gary Davis and 14 guests
