Locating, trimming, and gluing a fretboard http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=29021 |
Author: | James Orr [ Sat Sep 11, 2010 8:35 pm ] |
Post subject: | Locating, trimming, and gluing a fretboard |
I ordered this serviced fretboard from LMI about 10 years ago, and I'm happy to finally put it to use. ![]() 1) An initial leveling, to be repeated again once glued before fretting. 2) Trim it close, then use a small plan to trim it up to the nut slot. 3) Clamp it in place, then drill holes in a few fret slots and use the bits as guide pins during glue-up. 4) Trace the tape while it's clamped, then trim after. 5) Glue it on, level it after. |
Author: | Jim Kirby [ Sat Sep 11, 2010 8:58 pm ] |
Post subject: | Re: Locating, trimming, and gluing a fretboard |
I'd mark a good centerline on both the fretboard and the neck, for lining up later, and then taper the fretboard. I use the fretboard to guide the neck shaping, so I want the fretboard tapered to what I want the final neck to look like before it's glued on. I drill holes in fret slots for four guide pins (bits), 2nd and 11th frets I think, and then glue and clamp. Not sure what you are referring to with the tape. I do all the leveling and then fretting after the neck is glued on - that seems to be unusual here, but I can't see a good reason to do it differently. |
Author: | James Orr [ Sat Sep 11, 2010 9:33 pm ] |
Jim Kirby wrote: Not sure what you are referring to with the tape. Er, I mean "taper" ![]() Filippo Morelli wrote: It looks to me like your neck may already be at final width?] Correct. The neck is ready to go, minus the board. Neck is from Hanalei-Moon. |
Author: | Tom West [ Sun Sep 12, 2010 10:47 am ] |
James : I,m sure you have considered your string spacing on the bridge in re: to the taper of the fingerboard and neck. Tom |
Author: | alan stassforth [ Sun Sep 12, 2010 10:58 am ] |
since i am using dot markers only at this time, i drill those, then put a screw in a couple of those, then remove the screws and cover with the dots. i like filippos method though. |
