It is currently Wed Aug 20, 2025 9:48 am
 Post subject: OLF SJ 12 String
PostPosted: Sat Sep 04, 2010 8:59 am
A client asked me to do a 12 string for her and she loves the shape of the olf sj body. She hates the larger body of a lot of the 12 strings out there.
With some slight modifications can that shape de done in a 12 string??
Gary
 Post subject: Re: OLF SJ 12 String
PostPosted: Sat Sep 04, 2010 10:17 am
Don't see why not.
PostPosted: Sat Sep 04, 2010 7:22 pm
Got the parts for a 12 string on the way. Haven't decided on body shape yet. Anybody done an SJ 12?? Any tips???
Rob
PostPosted: Mon Sep 06, 2010 8:40 am
The general advice over the years has been to increase the top's thickness by ~10% and the bracing height by ~25%.
Never did an SJ 12 but I built a slope-shouldered Dred and was successful by using 5/16" wide x-bracing @ 5/8" tall at the intersection. The top was quite stiff but I still left it about 10% thicker than its sister 6 string dred. I also beefed up the bridge plate to compensate for the extra pull and extra holes.
PostPosted: Mon Sep 06, 2010 8:45 am
Thanks for the tips, I have a bit of time before I do it,
Gary
PostPosted: Mon Sep 06, 2010 10:42 am
I am sure it would work fine. In addition to JJ's comments I would also make the FOOTPRINT of the bridge plate bigger too, and make sure you brace the sound hole well. I would use a secondary patch and heavier braces around the hole.
PostPosted: Mon Sep 06, 2010 9:57 pm
My best guitar acoustically was an OLF SJ 12 string. My own bracing though.
Here it is
Graham Nash playing it
The bracing
Yes typically they are built a bit beefier. But my top of Shanes lutz was 0.090 That may seem thin for you but the way I build this is actually a bit thicker and stiffer than my typical OLF SJ. I did use 2 carbon fiber rods down the neck for added stiffness with the increased string tension. My X brace height was 0.65" before the cap.
Users browsing this forum: Gary Davis, Terence Kennedy and 16 guests
