Q on making bridge pins
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=28815
Author:  es guitars [ Sat Aug 28, 2010 6:02 pm ]
Post subject:  Q on making bridge pins
hi,
Started playing around turning some bridge pins. I was wondering if there was some math
I could use to come up with the tapper. I have some bought pins with a 5 degree tapper that I could measure but I am turning slightly larger pins for sub bass strings on my first harp guitar build.
Brent
Author:  TonyKarol [ Sat Aug 28, 2010 6:10 pm ]
Post subject:  Re: Q on making bridge pins
IMO you dont need larger pins for the subs on a harp .. the largest string is about 76, or possibly 80, and I use a std pin on the low B of my baritones which is a 70 .... I wouldnt go larger. What you wil need is a larger wider ramp for the string to sit in ... the pin will just hold it there. I am using 3 degree pins from Gurians ... they do have a larger bottom than the 5s obviously ... but you still need a 3/16 hole for the ball end to fit thru ...
Author:  Howard Klepper [ Sat Aug 28, 2010 10:09 pm ]
It's pretty near impossible to make them consistently on a wood lathe. With a metal lathe you set the taper angle with the compound slide.
