Question re Butt Joint Necks and Glue http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=28198 |
Author: | jac68984 [ Tue Jul 13, 2010 1:20 pm ] |
Post subject: | Question re Butt Joint Necks and Glue |
If you are using a simple butt joint with threaded inserts for your neck joint, do you use glue? If yes, do you glue the neck to the body, the fingerboard to the soundboard, or both? Thanks. Aaron |
Author: | TonyKarol [ Tue Jul 13, 2010 1:59 pm ] |
Post subject: | Re: Question re Butt Joint Necks and Glue |
only the underside of the FB .. unless you plan to use epoxy, glue elsewhere is useless, and then again, defeats the purpose of the bolts. |
Author: | Alain Moisan [ Tue Jul 13, 2010 2:15 pm ] |
What Tony said. |
Author: | jac68984 [ Tue Jul 13, 2010 2:18 pm ] |
Thanks for helping this newbie out. Many more questions to follow. ![]() |
