No OM Plans
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=28009
Author:  segovia [ Tue Jun 29, 2010 3:48 am ]
Post subject:  No OM Plans
Hi
I am starting number two (number one not finished yet).
Unlike number one which is a kit number two will be from scratch, it will be another OM. I have the mold and I have built the side bending form from a template taken from the mold. I don't have any plan for bracing - I am assuming that as long as I get the location of the sound hole and bridge correct in relation to the scale length the bracing should fit around that. I am going to cut my X brace lap joint at 98 degrees.
Am I going in the right direction or way off ?
Author:  CraigSz [ Tue Jun 29, 2010 6:01 am ]
Post subject:  Re: No OM Plans
John I am working on #4 at the present wich is an OM. My previous 3 instruments were dreads and based way too loosely on a set of plans from Jim Williams an Aussi builder. I thought I could easily mix and match ideas from other plans and patterns on builder's websites because I liked the sound of that particular builder's guitars. How wrong I was. gaah I realise now it really was just a hit and miss approach.Mostly miss. I will concede however that along with much frustration and an often sore forarm(shaving braces through the soundhole) I did learn some valuable lessons. My advice is to get hold of a proven plan and don't stray too far from the detail and dimensions shown. I think you will almost certainly end up with something you enjoy playing. I know Michael Payne has drawn OM plans which I hope to use in the future. I'm pretty sure John Hall from Blues Creek Guitars would also be able to help you. Also do yourself a favour and take lots of notes along the way so you can move forward with each build.
Regards
Craig.
Author:  segovia [ Tue Jun 29, 2010 6:16 am ]
Hi Todd
Great thanks, I have seen thsi site before and completely forgot about it.
