Neck shim
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=27980
Author:  segovia [ Fri Jun 25, 2010 2:38 pm ]
Post subject:  Neck shim
After I get the binding done I'll fit the neck.
At the moment the top of the neck is slightly below the surface of the top and isn't that tight.
Shall I shim the sides of the dovetail on the tenon ?
Author:  bluescreek [ Fri Jun 25, 2010 3:08 pm ]
Post subject:  Re: Neck shim
I make this shim dry and then glue it to the block when I glue in the neck . so I do it all at once
