It is currently Mon Aug 18, 2025 8:46 pm
 Post subject: Bending white oak
PostPosted: Sun Jun 20, 2010 10:26 pm
Ten years ago I bought 100 b.f. of quartersawn old growth U.P. white oak, intending to use it solely for craftsman style furniture. Never considered it for guitars until I saw Haans' beautiful parlor guitar. So, my question for him--or anyone else who's built white oak guitars--is, 'Any caveats regarding bending the stuff? And what temperature seems to work best for it?'
As always, thanks in advance.
J
michael propsom
www.propsomguitars.com
 Post subject: Re: Bending white oak
PostPosted: Mon Jun 21, 2010 12:40 am
Last Name: Abercrombie
White oak is the 'standard' wood for (steam-) bent frames (aka 'ribs') in boatbuilding in N. America, so you shouldn't have much trouble bending it, especially if it was air-dried. I'd bend it wet.
Other than that, I can't offer any first-hand advice. I've got a bunch of oak guitar b+s sets but haven't built anything with them yet.
PostPosted: Mon Jun 21, 2010 5:26 am
It's the easiest wood I ever bent. I sand it down to .090", spray it with SS2, let it dry for a day, wrap with a paper towel, spritz with water, and go at it. I get the rib up to about 250 degrees, bend the lower bout, then the upper, and by the time I start cranking the waist, it's around 275-290. I let it cool down, plug it in again and run it up to 250 for 10 minutes, and let it cool down again. Then I take out the blanket, upper slat and the paper towel and re-clamp in the bender overnite.
That's it...
PostPosted: Mon Jun 21, 2010 5:28 am
I don't use Super soft , this wood bends well and easy. 275 is a good working temp for it.
PostPosted: Mon Jun 21, 2010 6:07 am
John, SS2 is good insurance for a tight bend. I didn't use it on the first parlor, and had a few slivers of cracks at the waist. Probably just fine without for a dread, but they don't have a waist...
PostPosted: Mon Jun 21, 2010 8:58 am
Oak, white or red, ash, walnut, cherry: all woods easy to bend. Haans, .090" is stout!
I'd thin white oak to .075" without fear, and would just damp but not soak it.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Mon Jun 21, 2010 9:41 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I have some White Oak that I will be trying soon, but I have to say, unequivocally, that my local air dried Green Ash is the easiest wood that I have ever bent for guitar building.
I thinned it to 2mm, then dampened it, wrapped it win foil, and let it sit for about an hour. When I unwrapped it it was like wet leather. I could bend it cold, no added heat, just by pressing it to the mold with hand pressure alone. Add a few cauls so that it dries without any cupping and it sets very well. I was even able to get it to take a very tight cutaway bend.
I'm going to prepare a test piece of the Oak to see if it will behave similarly.
http://redrivercanoe.ca/
PostPosted: Mon Jun 21, 2010 10:26 am
Great suggestions all. Thanks so much. I was wondering about faceting or lifting dangers because of the strong medullary 'flakes' like in lacewood. Anyway, think I'll give it a shot in the near future.
michael propsom
PostPosted: Mon Jun 21, 2010 10:30 am
Just an afterthought. John A: Your reply reminded me that as a boy I used to watch my grandfather steam ribs for the lapstraked boats that he built. When he pulled them out of the steambox you could almost tie them in a knot. Couldn't remember if they were white or red oak, but probably the former since it's less prone to rot than red.
michael propsom
PostPosted: Mon Jun 21, 2010 11:40 am
Having bent wood for guitars over 10 years , I never needed SS2. In most cases I agree it may help for some people , my breakage rate is under 1%. I have more trouble with Flamed maple. In 3 years it is the only wood I broke. The runout in the figure is hard to control. Most well quartered woods will bend nicely but when you get into high figure you need to have a good process down for bending.
PostPosted: Tue Jun 22, 2010 5:36 pm
Last Name: Cox
Wet + hot = easy bending with Oak. It basically flops onto the form.
I would skip the Supersoft -- you won't need it.
You can bend ridiculously thick slabs into fairly tight curves with ease in Oak.... My Oak Ditson (About like a 0 size) had 1/8" thick sides... Bent easy... Could have left it thicker if I had wanted.
The main caution with Oak is to keep it away from Steel and Iron things when bending hot and wet.... The tannins in the Oak + contact with Iron + water = Ebonize.... Clamping damp Oak with Iron C-clamps = big black dots on your Oak.... Ask me how I know...
