It is currently Mon Aug 18, 2025 11:56 pm
PostPosted: Sun Jun 06, 2010 8:56 am
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
This is probably a classic newbie question, but I was planning on using a couple of the StewMac Ibex clamps to clamp the bridge on the parlor I'm making. I assumed that I'd attach a caul to the bridge plate, but there's one little problem I didn't anticipate.
My hand won't fit through the sound hole to attach the caul. Am I missing something really obvious? Is it sufficient for the lower arm of the clamp to press against the X braces?
As always, thanks in advance for any help.
PostPosted: Sun Jun 06, 2010 9:36 am
I'd say it depends on the glue. If you are using HHG, you can even do a rubbed joint. But plenty of folks have used clamping methods that do not have a caul internally. You just have to be careful with the pressure. The other option is to rig some kind of wider piece and stick it to your clamp with CA glue, which would protect the inside parts.
PostPosted: Sun Jun 06, 2010 12:16 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Heavy stress on the "small" square of double sided tape. Once a taped caul has been under clamp pressure for twelve hours or so, it can be very difficult to pry off. Especially if you can't reach it.
I often glue a small block of wood to the clamp & stick a piece of belt leather to the block as a cushion.
If you stick the caul down, a piece of sturdy string tied to the block would aid in removal.
Lots of ways to skin the cat.
PostPosted: Tue Jun 08, 2010 8:33 am
You can make cauls that have powerful magnets embedded in them and then just drag them into place.
PostPosted: Tue Jun 08, 2010 2:00 pm
Last Name: Abercrombie
On my first guitar (Sloane classical in the 70's) I 'forgot' the fingerboard clamping caul inside the guitar- it stayed there for a few years! (Not recommended, though I do wonder now if it had any effect, acoustically. Then, like now, I seldom ventured above the 12th fret, so wouldn't have noticed anyway...)
That double-stick tape is quite tenacious!
PostPosted: Tue Jun 08, 2010 3:04 pm
Well, this guitar doesn't sound exactly like I expected it to! Did it open up a lot when you took out the caul?
PostPosted: Tue Jun 08, 2010 3:22 pm
It was the fingerboard caul, and I didn't notice any difference when I removed it.
Now, a bridge caul - that should make a difference!
PostPosted: Tue Jun 08, 2010 3:27 pm
Hahah that's a funny story. Makes me wonder what I've left inside sound boxes in the past.
Users browsing this forum: kyle.medeiros, TimAllen and 27 guests
