It is currently Mon Aug 18, 2025 7:03 am
 Post subject: Go Bar Length??
PostPosted: Sat May 01, 2010 6:16 pm
I have a GB deck I bought awhile ago. It is non adjustable for height.
The go bars I got with it are fiberglass rods cut to length for that fixed height.
I now am using radius dishes composed of two thicknesses of mdf, so they
are 1 1/2".
My question is are my go bars now too long? Seems to me they might make too
much pressure now. Anyone have a formula to measure the pressure relative to
go bar deflection?
 Post subject: Re: Go Bar Length??
PostPosted: Sat May 01, 2010 6:32 pm
There was something a few weeks ago. If I understood it correctly, for a given go-bar material, once you've flexed them a little bit, the pressure remains unchanged until you've bent them a ton. The farther you bend them, the squirrellier they'll get though. Make sure you wear your goggles.
Mike Lindstrom
PostPosted: Sat May 01, 2010 6:39 pm
If you got that from Blues Creek you are fine. The standard length is 21 1/2" about the same as the opening . I brace on a 1 " disk with the same go bars you do and they work. You need to have about an 8 to 10 lb force
PostPosted: Sat May 01, 2010 7:21 pm
John, do you glue on your tops and bottoms with the go bar deck?
PostPosted: Sun May 02, 2010 6:51 pm
No I don't use a gobar for gluing tops and backs , I have a press.
Users browsing this forum: kfish, pkdz and 17 guests
