Masking a neck
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=27198
Author:  cgal_1 [ Thu Apr 29, 2010 11:11 am ]
Post subject:  Masking a neck
How much of the fret board should be masked before spraying? I've masked the top and sides, but get a ridge of varnish when I remove the masking. I'm concerned about sanding it down too far.
Author:  Fred Tellier [ Thu Apr 29, 2010 11:20 am ]
Post subject:  Re: Masking a neck
I only mask the top of the fingerboard, finish on the sides of it is normal and the masking line is on the edge and sands of easily.
Fred
Author:  Rod True [ Thu Apr 29, 2010 1:44 pm ]
Ya, what Fred said.
Author:  Ken C [ Thu Apr 29, 2010 2:02 pm ]
Pretty much as noted by Fred. I mask the top of the f/b, exposing just a hairline of the top edge. After spraying and removing the mask, I run a small sanding block along the top edge to break the finish then clean up the top of the f/b with a razor blade. Makes for a very clean transition.
Ken
Author:  cgal_1 [ Thu Apr 29, 2010 5:23 pm ]
So do you fret before or after spraying?
Author:  Darrel Friesen [ Thu Apr 29, 2010 5:31 pm ]
I fret before. Some fret after.
Author:  bluescreek [ Thu Apr 29, 2010 7:50 pm ]
I fret the board before I put it on the neck , Like Fred I mask off the top and clean up after. I don't like masking the sides , I want finish there and use the edge of the fretboard to be the separator.
