Archtop carving dilemna http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=26713 |
Author: | lactose [ Fri Mar 26, 2010 11:09 am ] |
Post subject: | Archtop carving dilemna |
I don't see an archtop room so I hope it is ok to post this here. I am carving my first top. When I drilled the contour holes for the top, I was unable to drill holes in the center due to the depth of my little drill press. This was not a problem since the center is the apex. After a lot of gouging, scraping, flap sanding and sanding, the top is pretty much done. But now I need to contour the back, and drill holes, mostly in the center, which my drill press will not do. So I am wondering how to contour the back. Some ideas are: -freehand the carving with the gouge or angle grinder, frequently checking the thickness with a gauge -make a thickness gauge that my hand drill mounts to, limiting the drilling to an adjustable depth -make a holder for my router similar to a pin router Any thoughts are welcome. ![]() Thanks, mark |
Author: | Dave Stewart [ Fri Mar 26, 2010 11:54 am ] |
Post subject: | Re: Archtop carving dilemna |
Mark, assuming you have a thickness gage I'd drill a hole in a block, chuck the drill & slip the block over as a depth stop. Mark an X at a point on the inside, measure the thickness, and expose the bit (out of the block) by the thickness LESS plate thickness you're targeting (3/8"?). Drill 'till block bottoms... repeat elsewhere. |
Author: | the Padma [ Fri Mar 26, 2010 12:31 pm ] |
Ya well, me gotts the same situation with me drill press so... I do it the old fashion way and just wing it with the chisels. blessings the Padma |
