Neck block paddle question http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=26396 |
Author: | sailorman [ Sat Mar 06, 2010 8:09 pm ] |
Post subject: | Neck block paddle question |
I am building a OLF small jumbo, my first build. Should the neck block paddle touch the upper transverse brace? the plans show about 1/8" gap. Wouldn't it be stronger if the paddle were glued to the UTB? I know it's end grain mahogany being glued to the spruce brace. I'm hoping to glue the top braces tomorrow and right now I have 1/16 measured gap between the paddle and the brace, I could move the UTB 1/16 forward to touch the paddle or I can trin the paddle to leave the 1/8 gap as drawn. Thanks for your help Rob |
Author: | Brock Poling [ Sat Mar 06, 2010 9:19 pm ] |
Post subject: | Re: Neck block paddle question |
sailorman wrote: I am building a OLF small jumbo, my first build. Should the neck block paddle touch the upper transverse brace? the plans show about 1/8" gap. Wouldn't it be stronger if the paddle were glued to the UTB? I know it's end grain mahogany being glued to the spruce brace. I'm hoping to glue the top braces tomorrow and right now I have 1/16 measured gap between the paddle and the brace, I could move the UTB 1/16 forward to touch the paddle or I can trin the paddle to leave the 1/8 gap as drawn. Thanks for your help Rob I make a firm connection between them. The thought being that the UTB can help shoulder some of the rotational force. |
Author: | Daniel Minard [ Sat Mar 06, 2010 11:36 pm ] |
I do the same as Brock. Just seems like the right thing to do. I think you need to make it tight & glue it, or leave a decent sized gap. You might get a buzz (of some sort) if they were touching but not firmly glued together. Maybe I'm just paranoid... On my last guitar, I glued the UTB into the linings & to the end of the "paddle", shaped the paddle & brace together, to get the FB extension angle I wanted & then glued the top onto the rim set & UTB. Don't know if I'll keep doing it that way, but it worked well. I did it that way because with the deep cutaway, I had to angle the UTB. It seemed easier to get it right putting the brace in first. I was thinking, it might be a good idea to glue a couple of wooden pins through the UTB into the paddle. End grain glue joints are prone to failure. |
