Classical guitar bridge: tie block http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=26355 |
Author: | Bob E. [ Thu Mar 04, 2010 11:23 am ] |
Post subject: | Classical guitar bridge: tie block |
I'm building a cigar box banjo and it will use nylon strings. For the tail piece I would like to imitate the tie block on a classical guitar bridge. However I've only ever seen picture of a classical guitar bridge. Is the tie block simply a rectangular piece of wood with string holes drilled through it, or am I missing an important detail? Thanks Bob |
Author: | WaddyThomson [ Thu Mar 04, 2010 11:34 am ] |
Post subject: | Re: Classical guitar bridge: tie block |
That's pretty much it, unless you want to get into multiple holes for each string. In reality, they're pretty simple. |
Author: | Bob E. [ Thu Mar 04, 2010 12:15 pm ] |
What about multiple holes for each string? |
Author: | WaddyThomson [ Thu Mar 04, 2010 1:01 pm ] |
Well, I have been using an 18 hole tie block for my classical guitars. Others like a 12 hole tie block. The 18 hole tie block keeps you from having any strings cross over the top of the block. The 12 hole allows the string to only cross the top of the block once. It just gives a neater look to the strung up instrument. Some don't like the look at all. Here is my last 18 holer. Attachment: P1020325 (Large).JPG
Author: | Bob E. [ Thu Mar 04, 2010 1:22 pm ] |
I like the looks of your 18 hole. Thanks |
Author: | JohnAbercrombie [ Thu Mar 04, 2010 4:37 pm ] |
WaddyThomson wrote: It just gives a neater look to the strung up instrument. [/attachment] It also affects the break angle of the strings over the saddle, which may be a good thing- or not. Some folks have also mused about increased chance of splitting the bridge with the extra holes, but I don't think this should be a big risk with a decent bridge blank. I think I'm going to give an 18-hole bridge a try next time. Waddy-thanks for the pic. Cheers John |
Author: | WaddyThomson [ Thu Mar 04, 2010 4:50 pm ] |
The biggest problem I've had so far, is that some "e" strings break (Maybe that's why it's a break angle ![]() |
Author: | Colin S [ Thu Mar 04, 2010 5:57 pm ] |
I also use the 18 hole bridge, as do an increasing number of builders now, one refinement I make is to use a 1mm bone plate on the rear of the bridge. Colin ![]() |
Author: | JohnAbercrombie [ Thu Mar 04, 2010 6:31 pm ] |
Colin- Thanks for that pic! Looks like a great idea...another one for the 'steal this!' file. Cheers John |
Author: | jlneng [ Thu Mar 04, 2010 8:24 pm ] |
Don't forget about the bone inlay in the tie block. It keeps the strings from damaging the wood. |
Author: | David LaPlante [ Fri Mar 05, 2010 2:40 am ] |
The thing I like the most about the 18 hole bridge is the opportunity to do some nice inlay without the strings over it. Attachment: LaPlanteSaddle-001.jpg Attachment: Siguenza-Bridge.jpg Attachment: Complete#90 004.jpg
Author: | WaddyThomson [ Fri Mar 05, 2010 11:02 am ] |
Here's my newest. Trial saddle still not trimmed down yet. Attachment: P1030220 (Large).JPG
