bearing against plexi
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=26150
Author:  mikemcnerney [ Fri Feb 19, 2010 6:44 pm ]
Post subject:  bearing against plexi
Has anyone ever run a flush trim or template bit, (the bearing) against their plexiglass tempalte to make another template? Or does it melt or damage it?
Mike McNerney
Author:  Dave Fifield [ Fri Feb 19, 2010 7:01 pm ]
Post subject:  Re: bearing against plexi
Mike, I use acrylic templates with pattern routing bits all the time. I've never had any heat problems. Plexiglas is more heat tolerant than acrylic. Go for it.
Cheers,
Dave F.
Author:  Bob Garrish [ Fri Feb 19, 2010 8:54 pm ]
Cheers,
Dave F.
Plexi IS acrylic
That said, it takes more heat than you should be putting into it with a bearing to melt. If you were letting the shank of the too rub, instead, then you'd need to make sure not to doddle.
Author:  Dave Fifield [ Fri Feb 19, 2010 11:36 pm ]
Yep, you're right Bob! I'm always mixing up Plexi and Lexan. Lexan is polycarbonate, right?
Cheers,
Dave F.
Author:  Bob Garrish [ Sat Feb 20, 2010 5:25 pm ]
Cheers,
Dave F.
Yep.
There are a lot of brand names for both. I end up buying most of my acrylic sheet branded as Lucite. It can get really annoying when looking for a specific product (like 'blue acrylic' or something) and finding nothing under 'blue acrylic' but loads of hits under 'blue Lucite' or 'blue Plexiglass' etc etc.
