Can you scrape zipflex? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=26128 |
Author: | Gtrman13 [ Thu Feb 18, 2010 6:31 pm ] |
Post subject: | Can you scrape zipflex? |
I'm doing a rosette on my next guitar right now. It's consisting of a BWB strip in one channel, a thin zipflex strip in a second channel, and a BWB strip in a 3rd channel. I decided to inlay the zipflex strip first, and it seems it actually sits a tiny bit out of the channel I routed for it. Is it safe to scrape this flush, Or do I need to sand it? Also, should I inlay the BWB strips before or after this is done? They'll need to be trimmed up also, but I know I can scrape them. Thanks. |
Author: | Dave Fifield [ Thu Feb 18, 2010 7:15 pm ] |
Post subject: | Re: Can you scrape zipflex? |
Yes, you can. I inlay Zipflex (using CA glue) so that it lies proud of the wood by about 4 or 5 mil, then use a freshly sharpened scraper to cut it clean with the wood surface. I checked the cross section of Zipflex before I did this to make sure the shell layers were thick enough, and they are, with plenty of margin. I would inlay everything including any bwb purfling before scraping/sanding, personally. Cheers, Dave F. |
Author: | Mike OMelia [ Thu Feb 18, 2010 9:52 pm ] |
That surprises me. Good to know, but not sure I would do that. |
Author: | Mike OMelia [ Thu Feb 18, 2010 10:12 pm ] |
(mainly because I am a chicken !) |
