Fretwire http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=26056 |
Author: | Laurent Brondel [ Sun Feb 14, 2010 1:33 pm ] |
Post subject: | Fretwire |
I've been using the "regular" .085" wide 18% nickel wire as found pretty much everywhere (I get mine by the pound from Euphonon). It's fine, but I find there is always slight variations in height, and always in need of light milling after installation when all the frets are perfectly seated. What do you guys think of the Jescar fretwire? Is it more consistent? Easier or more difficult to work with? I'd be willing to try the stainless steel wire, is it really that more durable? |
Author: | Hesh [ Sun Feb 14, 2010 3:08 pm ] |
Post subject: | Re: Fretwire |
Laurent my friend I can't speak about fret wire from Euphonon but I have and do use wire from Jescar and I am very pleased with it. As for consistency for the NS and EVO wire leveling is still required and not so much because of any variance in the wire but in the technique of the person installing it.... ![]() ![]() It's good stuff! |
Author: | Zach Ehley [ Sun Feb 14, 2010 3:35 pm ] |
Anyone know approximately how may linear feet are in a pound for standard wire. |
Author: | Howard Klepper [ Sun Feb 14, 2010 4:45 pm ] |
I've heard only good things about LMI's EVO wire and may give it a try soon. They don't have the size I usually favor (StewMac 155: tall, medium wide) but they have a few standard sizes. |
Author: | Laurent Brondel [ Sun Feb 14, 2010 5:29 pm ] |
Zach Ehley wrote: Anyone know approximately how may linear feet are in a pound for standard wire. Depending on the wire and according to StewMac, between 44 and 92f. The "regular" medium/medium wire gives 68f for 1lbs. That's a lot of guitars… |
Author: | ChuckB [ Sun Feb 14, 2010 5:45 pm ] |
I like the standard stainless steel wire. The durability is amazing,, but a little harder to work with. But not as hard as I thought. Using the Stew Mac diamond crowning files makes crowning easy. Worth trying. Chuck |
Author: | WaddyThomson [ Sun Feb 14, 2010 7:08 pm ] |
Laurent, you might check in with Mario P.(Grumpy), and see what he's using. He frets the board before installing, and does not, normally, have to level. I do know that he presses his frets in. |
Author: | MRS [ Sun Feb 14, 2010 8:42 pm ] |
I use wire from Jescar. I tried stainless and didn't like it. It sounded to bright to my ears. Bright sounding is not always a good thing. |
Author: | JJ Donohue [ Mon Feb 15, 2010 8:09 am ] |
I've been using Jescar SS fretwire more recently and have had great results on 3 builds. This material is definitely harder than the more traditional nickel-silver wire so it requires different cutting techniques. I like the fact that their wire arrives in a neatly consistent coil which obviates the need to run it through the fret radius jig. Installing is no different (I pound) and I find they seat more securely. Filing and polishing takes slightly more time but the frets stay polished and smoother much longer... I've never had to re-polish in over a year and there are NO string wear marks as well. Waddy...Mario posted his technique some time ago...check the archives under Grumpy. I have followed that advice with great success. I rarely have to level and re-crown a newly installed fretboard. BTW...he has been using Jescar SS wire for years now and won't use NS on a new guitar. There are some folks who, when they publish tips and advice, are sure bets to steer you in the right direction. |
Author: | cwood8656 [ Tue Feb 16, 2010 10:22 pm ] |
Is Jescar fretwire available direct, or do they sell through distribution? If distribution, who sells it? TIA, Chris. |
Author: | JJ Donohue [ Tue Feb 16, 2010 10:54 pm ] |
cwood8656 wrote: Is Jescar fretwire available direct, or do they sell through distribution? If distribution, who sells it? TIA, Chris. I've bought directly through Jescar. http://www.jescar.com/ |
Author: | Howard Klepper [ Wed Feb 17, 2010 12:58 pm ] |
Thanks Todd. |
Author: | Dennis Leahy [ Wed Feb 17, 2010 4:11 pm ] |
I'm pretty sure that Shane at High Mountain sells Jescar wire, and he would be my first choice of who to check. Hey Shane, if you are reading this, maybe you could list your stock wire sizes right here. Howard, I don't know in what quantity he needs to order for a minimum purchase of a specific wire size, but I'd ask him. Dennis |
