It is currently Fri Aug 15, 2025 2:10 pm
PostPosted: Mon Feb 08, 2010 2:29 pm
First name: Rob
Last Name: Dmitrieff
City: Boothbay Harbor
State: Maine
Zip/Postal Code: 04538
Hello, I'm building a OLF small jumbo and I'm a wondering the correct grain orientation for the neck block, Cumpiano says horizontal, however the neck block in the book is larger than what is drawn on my plans.Also the small jumbo neck block on my plans looks like two pieces, how does the grain run on the top piece? Thanks, Rob
PostPosted: Mon Feb 08, 2010 3:20 pm
First name: Christian
Last Name: Schmid
City: Edmonton
State: AB
Zip/Postal Code: T6E 1P9
Hi Rob,
I generally try to avoid having a glue joint with an end grain surface. That basically leaves only one 'correct' grain orientation (horizontal).
Christian
PostPosted: Mon Feb 08, 2010 3:40 pm
I run the grain in the same direction as the side wood. If you have conflicting grain , you run the risk of side distortion and cracking . Martin used the configuration for almost 200 years ,
PostPosted: Mon Feb 08, 2010 3:46 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Not to mention (and those above are the most important considerations) that sanding & shaping from the end grain is way rediculously difficult. I made this mistake once. Never again.
