Need Source for Performax 16/32 Abrasive Strips
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=25490
Author:  Paul Burner [ Thu Jan 14, 2010 6:12 pm ]
Post subject:  Need Source for Performax 16/32 Abrasive Strips
I'm in the need of some more sanding strips for my Performax 16/32.
In the past I purchased the "ready-to-wrap" ones form Klingspor, but I'm guessing there's a more economical and better choice.
Suggestions?
Author:  Mike Collins [ Thu Jan 14, 2010 6:49 pm ]
Post subject:  Re: Need Source for Performax 16/32 Abrasive Strips
Paul;
try www.customsandingbelts.com
Author:  David R White [ Thu Jan 14, 2010 7:51 pm ]
I have bought for the Delta from:
www.industrialabrasives.com
They're swell.
Author:  jsmith [ Thu Jan 14, 2010 7:59 pm ]
Check your Klingspor catalog. They also sell longer, cut-your-own lengths.
Author:  Jon L. Nixon [ Fri Jan 15, 2010 8:33 am ]
Klingspor or Rockler sell rolls, which are at least 50% cheaper that precut strips. You can also get the rolls with printed cut marks, but they are fairly expensive.
Author:  Jon L. Nixon [ Fri Jan 15, 2010 8:40 am ]
Author:  mnemotorsports [ Fri Jan 15, 2010 8:48 am ]
When you guys run your wood through the thickness sander what level grit do you go up to. Just wondering if I should purchase higher grit.
thanks
matt
Author:  WudWerkr [ Fri Jan 15, 2010 9:07 am ]
I sell the roll materials in my business , would be glad to get you price if u wish , need grit width desired and weight of the material , IE "J" or "X" weight cloth usally that info is on the back of the materials . also is it standerd or hook and loop , I dont sell the hook and loop materials.
wcaincj@aol.com is business email
Author:  Mike OMelia [ Sat Jan 16, 2010 9:37 pm ]
I love my Klingspor "Blue" paper rolls. Last forever. Save one of your used strips as a template.
Author:  Robert Dunn [ Sun Jan 17, 2010 5:27 pm ]
woodworker.com has pre cut and uncut.
