Fingerboard radius http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=25381 |
Author: | Edward Taylor [ Sat Jan 09, 2010 11:31 am ] |
Post subject: | Fingerboard radius |
What is your preferred one on an acoustic? |
Author: | SteveSmith [ Sat Jan 09, 2010 11:35 am ] |
Post subject: | Re: Fingerboard radius |
So far 16" although I would like to do a compound radius sometime. |
Author: | Tim L [ Sat Jan 09, 2010 12:14 pm ] |
I like 12" best. No problem with 14" or 16" but it seems a bit easier for my fat fingers to cover the board on a barre chord with 12". Tim |
Author: | BobK [ Sat Jan 09, 2010 12:15 pm ] |
I like 12. I did a 12 to 20 compound radius on my last one. I don't think you really "feel" the difference, but I've been able to set the action lower on it than any other guitar I've built, too low probably. Something like 070 on the bass and 045 on the treble. I'm wondering if that is due to the compound radius. Bob |
Author: | woody b [ Sat Jan 09, 2010 12:47 pm ] |
I use a compound 12" to 16" unless the client wants something different. In my mind a compound radius could allow for lower action. The string spacing spreads as you go up the neck, so the radius should spread also. Again, that's the way it works in my mind. As always, in real life YMMV. |
Author: | Edward Taylor [ Sat Jan 09, 2010 2:38 pm ] |
How do you guys go about doing your compound? Just transition with the blocks? |
Author: | BobK [ Sat Jan 09, 2010 2:57 pm ] |
I did mine on my DIY CNC machine, also did a sanding caul. Never tried doing one by hand, but I would imagine that 2 or 3 different radius sanding blocks could get you there. |
Author: | Bob Garrish [ Sun Jan 10, 2010 4:10 pm ] |
If you're going DIY on it then there are some neat jigs that'll do a compound radius. Mario used to use one, as well as some others, which had two pivots. I think I saw a commercial jig that got fed through a sander or somesuch. |
Author: | woody b [ Sun Jan 10, 2010 7:22 pm ] |
Edward Taylor wrote: How do you guys go about doing your compound? Just transition with the blocks? Here's a picture of my (really simple) jig. |
Author: | Edward Taylor [ Sun Jan 10, 2010 8:17 pm ] |
Woody that is very cool. I take it the inner piece has graduated slots as well? |
Author: | jncllc [ Sun Jan 10, 2010 8:20 pm ] |
I think luthiers cool tools has a plan for one that can do compound radiuses. |
Author: | LiquidGabe [ Mon Jan 11, 2010 11:20 pm ] |
I level the fretboard with a .75" sanding block, working from the outside to the center, following the angle of the edge of the fretboard, coming straight in the center and angling back out to the far side. This gives a compound radius, the longer you go, the bigger the difference between the two ends.... |
Author: | jonsse [ Tue Jan 12, 2010 5:45 am ] |
Edward Taylor wrote: How do you guys go about doing your compound? Just transition with the blocks? Does nobody use a Plane ! (or is that far too simple and easy) ![]() p.s. I don't use much pearl |
Author: | woody b [ Tue Jan 12, 2010 6:25 am ] |
jonsse wrote: Edward Taylor wrote: How do you guys go about doing your compound? Just transition with the blocks? Does nobody use a Plane ! (or is that far too simple and easy) ![]() p.s. I don't use much pearl I done my first 10 or so with a plane. I had inlays but didn't do them until it was radiused. |
Author: | windsurfer [ Tue Jan 12, 2010 11:26 am ] |
jonsse wrote: Edward Taylor wrote: How do you guys go about doing your compound? Just transition with the blocks? Does nobody use a Plane ! (or is that far too simple and easy) ![]() p.s. I don't use much pearl I use a plane. It allows me to quickly get very close to the desired result. Follow up with a couple of swipes with a block to assure everything is true. Dots are added after radiusing and I use a block to sand them flush. -jd |
Author: | mhammond [ Tue Jan 12, 2010 11:34 am ] |
Every time I try a plane it ends up tearing out chunks at one end or the other. What am I doin wrong? |
Author: | woody b [ Tue Jan 12, 2010 12:49 pm ] |
mhammond wrote: Every time I try a plane it ends up tearing out chunks at one end or the other. What am I doin wrong? You're taking too big a cut and/or your plane isn't sharp enough. |
Author: | windsurfer [ Tue Jan 12, 2010 2:25 pm ] |
mhammond wrote: Every time I try a plane it ends up tearing out chunks at one end or the other. What am I doin wrong? tear out should not be a problem with a well set up plane. I do radius before I trim to length, so even if I did get tearout at the ends it would be trimmed away -jd |
