Best way to remove pickguard? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=25116 |
Author: | Matthew Jenkins [ Mon Dec 21, 2009 9:22 am ] |
Post subject: | Best way to remove pickguard? |
Hi Guys I've just put an LMI self adhesive clear pickguard on my latest build. It didn't go on too well and I've got some small bubbles in it. I'm a bit nervous about peeling it off. The finish is EM6000. Would 'Acetone' be ok to use on the EM6000 when removing the pickguard? Many thanks Mat |
Author: | StevenWheeler [ Mon Dec 21, 2009 9:32 am ] |
Post subject: | Re: Best way to remove pickguard? |
Matt, Start with a hair dryer to soften the adhesive and peel the pickgaurd off. Mineral spirits will remove the adhesive from the finish. Steve |
Author: | Matthew Jenkins [ Mon Dec 21, 2009 9:37 am ] |
Thanks Steve ![]() |
Author: | jlneng [ Mon Dec 21, 2009 10:50 am ] |
I had to do the exact same thing on an earlier build which was finished with KTM9. I heated up the edge of the golpeador with a hair dryer and slowlyl pulled same off while heating same. I used goop be gone adhesive remover to get the adhesive off. That was more work than peeling off the plastic. |
