Shellac (FP) cold checking? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24890 |
Author: | Tim McKnight [ Fri Dec 04, 2009 11:57 am ] |
Post subject: | Shellac (FP) cold checking? |
Has anyone ever experienced or heard of FP cold checking like nitro? |
Author: | Michael Dale Payne [ Fri Dec 04, 2009 12:00 pm ] |
Post subject: | Re: Shellac (FP) cold checking? |
Tim if the shellac has experinced harsh heat then exposed to below freezing it can start checking but I have never had an issue. It seems the harsh heat makes athe shellac overly brittle once it hardens bak at a cold temp. But this is pretty rare to have happen. |
Author: | joekelly9692 [ Fri Dec 04, 2009 2:55 pm ] |
i had this happen once and i think i may know what caused it .....to start with i was using a rubber to put the shellac on so i was using an oil to lubricate the rubber....but then i decided to spray build and buff .........and a week or so later it had the most crazy cold dheck effect i have ever seen i think it maybe the oil trapped under the surface and its making its way out........does this have any resemblence to your situation tim? joe |
Author: | Cocephus [ Sat Dec 05, 2009 8:24 am ] |
I had this situation with the first guitar I built 3 years ago. I really thought this had something to do with the build-up being awfully thick, and the temprature extremes that I had to deal with back then. BTW, I french polished in late summer and didn`t notice anything until about December. It did get cold, but not below 45 degrees. I thought I was one of the few to have this happen. Funny thing about it is that my daughter asked me if I could make that "pretty patina" on her hope chest, and had to admit that I didn`t plan on it in the first place, and didn`t really know how it happened. It does give it character, though (or should I say done by a real character). Refinish it? No way. That guitar is done and I have no reason to change it at all, being #1. Coe Franklin |
Author: | Tim McKnight [ Mon Dec 07, 2009 9:26 am ] |
joekelly9692 wrote: i had this happen once and i think i may know what caused it .....to start with i was using a rubber to put the shellac on so i was using an oil to lubricate the rubber....but then i decided to spray build and buff .........and a week or so later it had the most crazy cold dheck effect i have ever seen i think it maybe the oil trapped under the surface and its making its way out........does this have any resemblence to your situation tim? joe Truth be told, I have never had a FP finish "cold check"... yet. I just wanted to know if anyone had ever had it happen. based on your responses, sounds like it is plausible though. I did subject a FP (top only) guitar to some temps in the teens and it never checked BUT it was in a room where the temps came down and back up very slowly and the finish was very thin. It wasn't subjected to an abrupt change which usually will make nitro check. |
