Slotted Pegheads http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24815 |
Author: | Mike OMelia [ Sat Nov 28, 2009 9:28 pm ] |
Post subject: | Slotted Pegheads |
OK, this is new terrain for me. I have seen Robbie Obrien's drill bit idea. And I like it. but you still have to make the template. So, how do you make an accurate template for something like this? What tools will you employ? Hand built? I have seen that jig, but its too expensive for me. Mike |
Author: | StevenWheeler [ Sat Nov 28, 2009 10:29 pm ] |
Post subject: | Re: Slotted Pegheads |
Check out what Hanns does. http://luthiersforum.com/forum/viewtopic.php?f=10117&t=21868 |
Author: | Mike OMelia [ Sun Nov 29, 2009 12:40 am ] |
So, that Lexan jig is made kind of like Haan's peghead technique? In pieces? Mike |
Author: | Mike OMelia [ Sun Nov 29, 2009 7:03 pm ] |
Todd, if you make it out of wood, what is the lexan needed for? Mike |
Author: | Mike OMelia [ Sun Nov 29, 2009 7:25 pm ] |
OK. Thanks. I have been studying this on and off all day as I have been fitting the neck joint. One thing I noticed is that the string hole in the slot tuners may not be centered in the slot (if I follow the plans exactly). Should the string hole be centered in the slot? Sorry, new to slots. Also, in Todd's last picture, did you cut the square holes in the templates by hand? Mike |
Author: | Mike OMelia [ Sun Nov 29, 2009 8:19 pm ] |
Ahhh, got it. Thanks Todd. Anybody have info on locating the string hole in the peg? Should it be centered in the slot? Mike ![]() |
Author: | Mike OMelia [ Mon Nov 30, 2009 11:06 am ] |
Don't use the bushings? |
Author: | Mike OMelia [ Mon Nov 30, 2009 6:21 pm ] |
I think I need a specific link on this: Grobet sculpter's file Woodcraft was no help. Mike |
