Bolt-on necks
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24768
Author:  Edward Taylor [ Wed Nov 25, 2009 2:25 pm ]
Post subject:  Bolt-on necks
What do you guys think about strictly bolt-on necks with no mortise/tenon? Do you have to inset the heel on a bolt-on or does it sit right on top of the sides? Has anyone used the kit from luthiers cool tools?
Thanks a bunch
Author:  Michael Dale Payne [ Wed Nov 25, 2009 2:35 pm ]
Post subject:  Re: Bolt-on necks
Right on top of the sides is fine you do not need to inlet anything. My only dislike about a true butt joint bolt-on is that you have the oversize tolerance of the bolt hole to deal with. This allows the neck to yaw a tad until the bolts are drawn tight. This requires that you continually check and adjust alignment till you have the neck torque down. Structurally it is perfectly fine.
Author:  David R White [ Wed Nov 25, 2009 7:49 pm ]
Yup, just butt it up against the sides. I've used this for years.
Author:  dmorg57 [ Thu Nov 26, 2009 8:05 am ]
Hi Edward, I have constructed a couple of guitars based on the information from RM Mottola. Really straight forward and a real sinch to fit and do a reset when the time comes.
See this link http://liutaiomottola.com/construction/Bolton.htm
Author:  Edward Taylor [ Fri Nov 27, 2009 10:29 am ]
So its best to keep the heel beefy for the inserts? Also is it safe to use a smaller neck block?
Author:  woody b [ Fri Nov 27, 2009 12:44 pm ]
I can't answer about the neck block, and I don't use this design, but I'd recommend installing a dowel through the heel, from the fingerboard to the heel cap. This strenghtens the heel and gives the inserts something to thread into that's not end grain.
Author:  Edward Taylor [ Fri Nov 27, 2009 12:48 pm ]
That sounds like a good idea, some use that in a tenon/mortise as well right?
Author:  Hupaand [ Fri Nov 27, 2009 3:07 pm ]
I've done only 12 butt-joint bolt ons. The first few were trouble finding workable dimensions. The rest have been fine. You don't need a particularly big heel. Enough for a half inch thread or so. I wouldn't skimp on the block, though. I learned that the hard way, too. The joint is strong with a thinner block, but the top dips without that support. I'm trying to figure out how to repair it.
