Double UTB - how big should I make each of them http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24687 |
Author: | PeterDeWitt [ Fri Nov 20, 2009 10:25 am ] |
Post subject: | Double UTB - how big should I make each of them |
I plan to use double upper tansverse braces. My bracing stock is Lutz. Anybody have suggestions on what width and height I should probably make each of the UTB's? If it matters, the upper bout is about 11" wide on my model. Thanks, Peter |
Author: | Rod True [ Fri Nov 20, 2009 10:41 am ] |
Post subject: | Re: Double UTB - how big should I make each of them |
Hey Peter, I use two larger upper transverse braces, each is 3/8" wide x 5/8" high. |
Author: | PeterDeWitt [ Fri Nov 20, 2009 10:46 am ] |
Thanks, Rod. I had guessed about that. Appreciate it. Peter |
Author: | Tom West [ Sat Nov 21, 2009 8:49 am ] |
What is the logic of using a double UTB rather then a deeper and wider one...? |
Author: | ChuckB [ Sat Nov 21, 2009 9:05 am ] |
Westca, although I do not use two UTB braces, I would think that the uppermost brace would be a good place to bolt down the fingerboard extension if you use that type of joint,, also would double as a popsicle brace? Chuck |
