It is currently Wed Aug 13, 2025 7:14 am
PostPosted: Sat Nov 14, 2009 3:25 pm
First name: Corky
Last Name: Long
City: Mount Kisco
I've got some Sapele from the local lumber yard at a very resonable price - in blocks that can easily be cut into neck and tail blocks.
I'm assuming that the properties are very similar to Honduran Mahogany and as such can be used as a substitute for Honduran in neck and tail blocks. Reasonable assumption? Thanks.
PostPosted: Sat Nov 14, 2009 3:40 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
I`ve used them with no problems.I`ve also used Khaya with no problems.I`m pretty sure LMI sells them,so they must be fine.
James
James W Bolan
Nashville Tennessee
PostPosted: Sat Nov 14, 2009 5:51 pm
Last Name: Speller
City: Rodney
taylor is using sapele necks now and its a good substitute.
PostPosted: Sun Nov 15, 2009 5:42 am
Last Name: Ressler
City: Sandwich
State: IL
Zip/Postal Code: 60548
I've been using sapele for end blocks and necks for some time now. It is a little heavier than Mahogany, but I have had no issues from it at all. It finishes beautiful and is great to work with
John Ressler
PostPosted: Sun Nov 15, 2009 5:06 pm
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Zip/Postal Code: 43201
Todd,
Does it matter how you orient the "grain" of the baltic birch ply when you use it for tail blocks?
Peter
PostPosted: Sun Nov 15, 2009 10:43 pm
First name: Peter
Last Name: DeWitt
City: Columbus
State: OH
Thanks, Todd.
Peter
PostPosted: Mon Nov 16, 2009 8:36 am
Last Name: Cox
I think some sort of ply is almost ideal for the tail block... It is nice to have something hard to split.
In my rooting around inside guitars... I have found almost every sort of wood blocks imaginable. I am surprised how often I see plain 'ole spruce, pine, and fir are used for both head and tail blocks..... Those guitars sound just find -- so in my mind... if those make good guitars (And they appear to..) you could use most anything.
PostPosted: Mon Nov 16, 2009 8:40 am
Last Name: Cox
In my rooting around inside guitars... I have found almost every sort of wood blocks imaginable. I am surprised how often I see plain 'ole spruce, pine, and fir are used for both head and tail blocks..... Those guitars sound just find -- so in my mind... if those can be used in good guitars (they appear to..) I think you could use most anything.
So far, I have personally just used whatever wood I used for the body... which is Mahogany, Cherry, and Oak.
PostPosted: Mon Nov 16, 2009 9:08 am
I plan on useing ash, walnut, cherry, and maple in mine.I have some spanish cedar that i will use as well.
PostPosted: Mon Nov 16, 2009 9:13 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've used baltic birch ply for end blocks, but I've used up all I had. I've got some Spruce top wood that isn't stiff enough. I'm going to make my own laminated end blocks from them while supplies last. I normally make my neck blocks from the same material the neck is made of, usually Mahogany or Maple. I don't see how Sapele would cause any problems.
Todd, others, didn't Martin used to put a strip of Maple on the inside of their Mahogany tail blocks to help keep them from splitting? That might be a good idea with a solid end block. It could be made to look good if looks inside the box are important.
Users browsing this forum: doncaparker, Facebook [Bot] and 13 guests
