Dovetail neck setting videos on You Tube are out
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24593
Author:  bluescreek [ Sat Nov 14, 2009 6:52 pm ]
Post subject:  Dovetail neck setting videos on You Tube are out
http://www.youtube.com/watch?v=L3YJh9OT4mw
here is a link to the 1st dovetail neck setting video. I try and explain in detail all you need to know to be able to set a dovetail neck. Let me know your input . I hope you like them
BCG
Author:  Ron Belanger [ Sat Nov 14, 2009 8:14 pm ]
Post subject:  Re: Dovetail neck setting videos on You Tube are out
Hey John,
Terrific video. It comes at an opportune time for me as I am considering moving from a bolt on to a dovetail neck joint. I really like the clarity and your common sense approach to building. Looking forward to #2.
Author:  letseatpaste [ Sat Nov 14, 2009 8:23 pm ]
Really well done, John, thanks for posting these. Just got done watching the first two and am about to watch the rest of them.
Author:  bluescreek [ Sat Nov 14, 2009 8:30 pm ]
thanks for the kind works . I hope I can take the mystery out of the dovetail joint
Author:  Fred Tellier [ Sun Nov 15, 2009 10:46 am ]
Good videos John, you are getting quite good with you presentation skills and I like all of the topics you have covered so far.
Fred
Author:  Bailey [ Sun Nov 15, 2009 1:55 pm ]
Great Sunday morning class for this old guy. Never to old to learn anything. Very detailed.
Kent
Author:  Haans [ Sun Nov 15, 2009 4:02 pm ]
Very nice John!
Will you do a follow up on after it's finished? Seems as though you left off with the neck a little proud of the box...do you consider glue and finish on the ribs? I usually end up dead flat on the top... or were you flat on the top also?
Author:  bluescreek [ Sun Nov 15, 2009 7:16 pm ]
the guitar is in the white and I like to keep ita touch proud. Once I have it finished I will set the neck and keep it about .010 above the top so that I have a true wedged joint. You need the neck joint to pull tight.
Author:  Haans [ Mon Nov 16, 2009 7:40 am ]
Thanks John.
Author:  enalnitram [ Mon Nov 16, 2009 8:14 am ]
Thanks John! I'll probably watch this one more than once.
Author:  Philip Perdue [ Mon Nov 16, 2009 6:42 pm ]
John,
Thank you for the tutorials! They have been posted at an opportune time as I’m about to set a dove tail neck and really don’t have a good concept of it. It was a little hard at times seeing what you were describing since the camera didn’t always capture the detail. But with your help I’m sure I can move forward now. bliss
Philip
Author:  bluescreek [ Mon Nov 16, 2009 6:49 pm ]
feel free to contact me through my website. I am here to help
john
Author:  John Hale [ Mon Nov 16, 2009 7:16 pm ]
Any chance of a dvd on how you cut the joint I assume you rout yours? I watched people cutting them by hand in my evening class then gluing shims in sanding and chiselling over shooting the mark then adding another shim seemed a nightmare that's why I opted for bolt on
Author:  bluescreek [ Mon Nov 16, 2009 7:54 pm ]
I use cut dovetails I don't like to cut the block after the guitar is built.
