Seal coat of shellac before routing for the binding?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24274
Author:  matthewrust [ Wed Oct 21, 2009 11:11 pm ]
Post subject:  Seal coat of shellac before routing for the binding?
I have always routed for binding in the white, but am wondering if it would help to avoid tear-out if I put a thin seal coat of shellac on the sides before routing. Of course, I will scrape and sand before my finishing schedule. Does anyone else do this? Pros/cons?
Thanks!
Author:  Robbie_McD [ Thu Oct 22, 2009 12:00 am ]
Post subject:  Re: Seal coat of shellac before routing for the binding?
Yup! A spit coat or two of blonde does wonders.
Along with a spiral downcut bit you get a razor-sharp edge every time...
Author:  peterm [ Thu Oct 22, 2009 1:41 am ]
I don't see any problem with doing it but don't see any reason to do it either. Just another step to brush it on and sand it off. I do it after I cut the channels to protect the end grain from the CA glue.
Author:  Alexandru Marian [ Thu Oct 22, 2009 2:35 am ]
I am sealing with shellac generously before I start cutting, but I don't see how it can really protect from tearout. Best tearout protection is to pre-score with a sharp gramil.
What I find the sealcoat invaluable for is to protect the top from the sticky fishglue I use and the binding tape. I still tend to pour too much glue and that makes a real mess.
Author:  Pat Hawley [ Thu Oct 22, 2009 7:59 am ]
But what if you intention is to later pore fill with epoxy? My impression has been that one does not put epoxy over shellac.
