Plans for Norman Blake 000-18 model
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24248
Author:  Richard Sutherland [ Mon Oct 19, 2009 4:18 pm ]
Post subject:  Plans for Norman Blake 000-18 model
Are these available? Thanks.
Author:  Zach Ehley [ Mon Oct 19, 2009 4:32 pm ]
Post subject:  Re: Plans for Norman Blake 000-18 model
John Hall should be able to get you a tracing with the brace locations. I've never seen full plans.
Author:  Fred Tellier [ Mon Oct 19, 2009 5:16 pm ]
I got a tracing from John Hall and the bracing is basically the same as a standard 14 fret 000/OM with the bridge plate moved to the correct placement for the martin short scale and a 12 fret neck. My only concern was that the bridge was only above the X brace on its front corners, but other builders replied on a previous thread that this will not pose a problem. When I get to it mine will be a cutaway.
Fred
