Help with tint-color for neck. http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=24075 |
Author: | Lars Stahl [ Tue Oct 06, 2009 8:12 pm ] |
Post subject: | Help with tint-color for neck. |
Hi all. I am workin on a Cocobolo B/S guitar. the neck "mahogany" feels way to bright for being a good match. Question is. what are you guys using for tinting the neck. Just want it one step darker/redish or brownish. Can I use any kind of water/alcohol based tint ? or is there anything you would recommend. also whats the best way to put it on. Drytime/sand etc. procedure!: Thanks in advance, Lars. |
Author: | peterm [ Tue Oct 06, 2009 8:26 pm ] |
Post subject: | Re: Help with tint-color for neck. |
Lars Stahl wrote: Hi all. I am workin on a Cocobolo B/S guitar. the neck "mahogany" feels way to bright for being a good match. Question is. what are you guys using for tinting the neck. Just want it one step darker/redish or brownish. Can I use any kind of water/alcohol based tint ? or is there anything you would recommend. also whats the best way to put it on. Drytime/sand etc. procedure!: Thanks in advance, Lars. There are a lot of good solutions and good products available. I would stay away from water based as I don't like to introduce any moisture into the wood....specially the neck. |
Author: | Lars Stahl [ Wed Oct 07, 2009 6:09 am ] |
Thanks Peter. If anyone else has more info , It would be most appretiated. Lars |
Author: | Arnt Rian [ Wed Oct 07, 2009 7:13 am ] |
Here's a mahogany / EIR one I did with the Colortone liquid stains from Stewmac. I used medium brown, tobacco brown and possibly some vintage amber, all reduced in alcohol and applied to the bare wood with a rag. This instrument was then finished with nitro. ![]() |
Author: | Lars Stahl [ Wed Oct 07, 2009 10:13 am ] |
Thanks alot Arnt. great info and help. I was just looking at those colors at stewmac. will get them then. ![]() ![]() Lars. |
Author: | John Hale [ Wed Oct 07, 2009 5:51 pm ] |
From another thread bluescreek wrote: I use CA to fill and as for necks , if you want to get a good match to the rosewood , I use red mahogany stain first follwed by Dark brown Mahogany stain , then use a blackened filler. I will go to 320 grit to stain and fill . If the stain doesn't work even I will use 320 grit sandpaper and sand stain to even the color.
I don't use water stains but have used aniline dyes |
Author: | Lars Stahl [ Thu Oct 08, 2009 6:10 am ] |
Thanks alot John for finding the info . and also thank you John Hall for the writing the info ![]() I have 2 bottles on the way now. one is Red mahogany stain and the other is medium brown same type as Arnt suggested. so hopefully it will go fine ![]() Lars. |
